Rnemhrd
Rnemhrd's Avatar
11.26.2008, 08:15 PM
Nice ride. There are a lot of x1 crts out there. Mine came with a six gear spider diff with a 52t spur. Not sure if I can change it so I am running it. Good luck with your build. Also I fit a traxxas water proof reciever box where your reciever is.I used a e maxx one but think the slash one is a little smaller. Drilled and tapped the servo plate.
cheesecake
11.26.2008, 09:10 PM
sweet thats good to hear if you need any help dont hesitate to get ahold of me i can help you get it straightend out
riverat1540
riverat1540's Avatar
11.29.2008, 12:22 PM
gonna need a custom battery tray from mike and i already ordered the zippy 5000mah 5s pack witch is 160 x 51 x 40mm and i dont want to mount it on its side how big should i have him make the tray? also the .25 cut out on the bottom of the tray is that to go over the mud gaurds or just so u can mount it close to the lip. am also looking for the side mudgaurds but can not find them anywhere. can anyone help?
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
Rnemhrd
Rnemhrd's Avatar
11.29.2008, 03:51 PM
That chassis is so wide it does'nt use them. You could make some fit I guess if you really wanted them. Or do a x2 chassis conversion also. I would have but mine has the 7075 pro chassis. Maybe if I bend it.
riverat1540
11.29.2008, 03:53 PM
ok was just wondering if they were made for it as i sw the mounting holes
Rnemhrd
Rnemhrd's Avatar
11.29.2008, 04:07 PM
This http://www.rcproductdesigns.com/imag...op%20Plate.jpg ex1cr top plate from here http://www.rcproductdesigns.com/EigthScaleParts.htm will alow you to mount the esc over and behind the center diff and get the esc out of dirt. See http://www.rcproductdesigns.com/Jammin%20index.htm I like mine. Keeps the esc high and dry. Raises the COG a bit but I like the esc out of the way. It is the plate on top. The motor mount is seperate.
riverat1540
11.29.2008, 04:12 PM
ty thats a sweet idea
plus i think im gonna need the room for the battery its 160x50
Rnemhrd
Rnemhrd's Avatar
CRTIM has a nice pic of it mounted. http://www.rc-monster.com/forum/showthread.php?t=16827
big greg
11.29.2008, 05:31 PM
i have a tray for you hold on.....
http://www.neweramodels.com/item.cgi?part_id=1952
its 51 mm wide, i have one on my crt and it is perfect width for the zippys, i drilled and tapped my chassis and used countersunk screws to hold it down
riverat1540
11.29.2008, 05:37 PM
i like how it looks what is the length of this tray?
big greg
11.29.2008, 05:48 PM
i think it might be perfect, but i opened the one end of it, since the strap holds the baterry really, i also put some velcro in the bottom, ill get a pic of it mounted in my car
riverat1540
11.29.2008, 05:50 PM
that would be great
big greg
11.29.2008, 05:55 PM
riverat1540
11.29.2008, 05:57 PM
cool looks like that will work just fine for me
big greg
11.29.2008, 06:01 PM
yup that is the 4s 4000 zippy-h those are great packs~!
