Thanks, but I need to round all the edges and whip up a support for the rear of the motor. Since I will be using a hacker c50 xl motor I may just make another L bracket to bolt to the rear of the can and attach on top of the current bracket.
And I really need to polish it up, looks kinda ratty... Never really finished it while it was on the lst cause I had the tdr mount on order.
yea thanks for the pic, btw do you think if i ran anything lower than a 24t pinion on the kb 8xl, will it get to hot? i do plan on making my own mount and see how that turns out. ill probably shave the shaft to 5mm also so i ill be able to use mikes mod 1's this way i got more of a variety, im worried about having the motor hit the transmission with a smaller pinion because it will need to be in closer.
