Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
plettenbergs
plettenbergs's Avatar
02.19.2009, 06:13 PM
the UE diffs are the bomb!!!i run the spider8's in my dual Plettenberg Lightning and they have held up just fine ,SO FAR!
i am going to install one in my rc8t center diff when i get some time
i also have a couple Fioroni diffs i might try??
Rnemhrd
Rnemhrd's Avatar
02.19.2009, 06:29 PM
Just ordered the 8 spider diffs. Just have to figure out the gearing for the 3905 tranny. I want it around 45 to 50. Just enough to make the nitro guys go
George16
Supermaxx
George16's Avatar
02.20.2009, 03:29 AM
The UE spider diffs are nothing but the cheaper Ofna/Hobao diffs which comes in eithe 6 or 8 spiders. UE just added their own diff outputs. You can buy them from dinballrc.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.21.2009, 08:52 AM
Yea, you can get the 6-spider diffs for $20-$22 each and the 8-spiders for $32-$39 each if you find the right guy selling them, and others are selling the 8-spiders for $65-$75 each. When you are looking for 6-spiders, just remember that any Hyper diffs will work, and I think a couple other ofna diffs (Lito "george16" knows for sure)...when you are looking for the 8-spiders, you can find them listed as either "spider diffs" or "torsen diffs".
-Chad
PM ME IF YOU HAVE THE BELOW:
jayjay283
jayjay283's Avatar
02.25.2009, 06:55 PM
1/8TH DIFFS MAY BE THE DEAL, oH YAY YOU SAVED $45 DOLLERS, Robin through in every single shim I may need... Cry on cousins.... $50 I smoke you...open bet
What????
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
What???? - 02.25.2009, 07:02 PM
What??? What are you smoking???? Can anyone else understand that?
SUPERMAXX YOUR LIFE.
Rnemhrd
Rnemhrd's Avatar
02.25.2009, 08:20 PM
Jerry, I signed up at UE when you first posted the monoblocks were up for pre-order but can't view anything. What would be the best way to get info? Thanks. Jayjay, If ever in central NY we can find out.
Not sure.
JERRY2KONE
JERRY2KONE's Avatar
Not sure. - 02.25.2009, 10:55 PM
Not sure what your hold up may be, but here is the link for the monoblock thread.
http://www.unlimitedengineering.com/...9&page=1&pp=40
If you still can not view it, then I would suggest sending an email to Robin at
(forumadmin@UEusa.net). He may not answer you right away, but if you do not hear from in a few days sind him another one. Somtimes emails get lost in the junk mail bins. Here are some pics of one of my projects with a double monoblock setup.
Good luck with your quest Sir.
Rnemhrd
Rnemhrd's Avatar
02.26.2009, 08:34 PM
You sure you need a wheely bar on that thing? Very nice!!
vBulletin Message
rnemhrd, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
This is what I've been getting. Thanks though.
Not sure.
JERRY2KONE
JERRY2KONE's Avatar
Not sure. - 02.26.2009, 09:19 PM
Yea I am not sure of anything just yet with this build. I have been prototyping this project for over a year now while working on three other trucks at the same time (multitasking). This one is surely a special build that takes time and a lot of changes along the way to make sure it reaches all of the goals that I intend for it. The wheelie bar will actually and more than likely go onto one of our sons trucks, since we know it is needed there.
as for your UE communication issues, I have had that same messege a few times when I first started on UE. Somehow I sent an email to Robin and he cleared it up for me. He has to personally go in and activate each account once you have logged into the system or maybe one of the Moderators can help. He may be just a bit busy with all of the new parts production going on. Outside of this you may be banned for some reason that we are not aware of. Bottom line is that you have to discuss this directly with Robin, who is the owner of the site.
Rnemhrd
Rnemhrd's Avatar
02.26.2009, 09:25 PM
No biggy. He has the monoblocks listed as in stock now. Do you know off hand how long the extended dogbones for the thunder chassis and monoblock are? I know jayjay used a 147mm on his stock E Maxx. I am using a FLM 3905 chassis that should be the same. Thanks
Tags
dont miss out on this
