03.08.2009, 08:17 PM
Originally Posted by fastbaja5b
In regards to this comment of yours over there:
"Until then, I would question the Trucks ability to run 3s Lipos reliably at least until someone puts out a better guideline as to what packs we should and shouldn't run."
The truck is just fine on 2 X 3S lipos. IMO, just buy something other than Zippy's and don't gear it stupid high. Mine runs just fine on 2 X 3S Neu 25C 4900's, Badlands and 20:44 gearing.
03.08.2009, 10:08 PM
Yeah mine has been fine on 2 * 2s lipos (2 * 5000mah 30C Harris rc hardcased)
Seems most of these issues are with Maxamps or Zippy lipos?
I <3 RC
03.09.2009, 01:26 AM
That thread you posted does not indicate in any clear manner that the Zippys were responsible for the failure, especially since the other truck is apparently still running fine. I love it when speculation becomes fact.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
03.09.2009, 01:29 AM
My Zippy-H 5000 mAH 20-30C pack held up fine with a MGM 16018 and a Neu 1515 1.5D, there's nothing wrong with their cells as long as you don't get stupid with them.
I <3 RC
03.09.2009, 02:14 AM
I too use a pair of those 3S packs in my E-Revo. Till recently I had punch at 0%, but eased off because drive shafts have started creaking. Waiting till they go completely bust to get a set of the new BLE/Summit CVAs.
AX10 RTR - Stock :D
03.16.2009, 08:11 PM
ok, the question i got is how can we purchase the MMM's and them reliable enough to run lesser packs? i cant afford some of the prices for "higher end" lipos so i guess i try it and cross my fingers?
Site Owner
03.16.2009, 08:53 PM
The answer is to not expect the performance of a higher end pack out of the low priced pack you can afford. If you can't afford the "Ferrari" then you can't afford it, but you can't buy a "Chevy" and complain that it isn't a "Ferrari", either.
It isn't the low end packs in and of themselves - it is the low end packs being used like high end packs that are the issue. If you want to see the 60mph speed on the box of the ERevo, you need to have Ferrari packs to do it reliably. If you have the Chevy packs, then don't try to reach Ferrari speeds and you should be fine.
03.16.2009, 09:02 PM
Great metaphor!
05.30.2009, 07:35 PM
Originally Posted by Jeremy1976
Great metaphor!
Would be BUT, there are a couple of Chevy products that will run with a Ferrari. The Z06 Corvette and the ZR1 Corvette. There's always a fly that will land in the ointment.
03.16.2009, 09:03 PM
Or, run two such Chevys in parallel to achieve the Ferrari capabilities
03.16.2009, 09:28 PM
Nah, not even close... Nothing like a ferrari... Not that I really like them that much, but they are fun to drive. Like comparing a 4 cyl sportbike to a built buell. Anything that can turn high rpms and pull stupid speed is in a league of its own..
03.16.2009, 10:40 PM
Ummmm..........I don't understand!
The Chevy packs would be the best ones.
Now if you had said "Ford Packs", I could understand the lower quality.
03.17.2009, 02:45 PM
right on! rofpimp!
03.17.2009, 09:10 AM
Well, there have been failures on other packs as well - most recently on a set of Mikes packs. Whether or not these failures had anything to do with the batteries, I'm not qualified to answer. (or if having a different set would have prevented the failure).
03.17.2009, 01:11 PM
hopefully your not talking about my mistake of hooking up mikes 5s 2500mAh packs in series instead of parallel, that is obviously not the monsters fault when it failed.
And on a side note the packs performance is off the charts!!! Thanks Mike!
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
