Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
Where does it work....
jhautz
jhautz's Avatar
Where does it work.... - 03.26.2009, 10:51 PM
I was just thinking that it would be nice to have a place where people can list what vehicles they have installed the slipperential into, how it fit, and if any mods were needed to make it work. It should be pretty universal in size and drop right into a large majority of vehicles, but I'm sure it will take some minor mods to make it work well in others. So when you get one installed post up here with some pictures and any useful information that others running that same vehicle might want to know. An easy place for others to be able to look and see where it works and how.
I'll Start. Installed it in my RC8T tonight. It dropped right in, no mods needed. It has a smaller 46T spur gear vs the 54T stock gear or the 50T optional RC8T gear I was running so I needed to drop a tooth in the pinion to get the overall gear ratio back to the same as it was before. I will probably be looking for the optional 50T slipperential gear once its available.
(Camera batteries are dead so I'll post some pics of it installed later tonight or tomorrow once I get it charged up.)
EDIT: Was just looking it over a little closer and saw that it actually was just slightly rubbing the center diff top plate. I just shaved the side of spur gear slot in the top plate down ever so slightly with a hobby knife and its no problem. Just something to look for if you put one of these in a RC8T.
Picture added:
to make it...
or break it...
Silent...But Deadly
MetalMan
MetalMan's Avatar
03.26.2009, 11:15 PM
Some quick speculation tells me it should fit in all Ofna Hyper series, Jammin cars/trucks, and Losi 1/8 should be fine. It likely won't fit in XTM stuff (XTM diffs are a tad longer), or the SH Z-Car (this buggy uses a shorter diff). Other than these, I dunno.
Shark413
Shark413's Avatar
03.26.2009, 11:48 PM
It won't fit in a Kyosho M9 either, it also uses a smaller diff.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
jhautz
jhautz's Avatar
03.27.2009, 12:11 AM
Yep. Not a chance.
It should work in Mugen, AE, Xray (808 may requre raising the diff mounts since stock gearing is 42T,but any of the older ones and the XT8 No problem), Caster, Losi.
to make it...
or break it...
Silent...But Deadly
George16
Supermaxx
George16's Avatar
03.27.2009, 01:47 AM
What about the ST RR? I know ofna hyper diffs have the same dimensions as the ST RR diff case.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
MetalMan
MetalMan's Avatar
03.27.2009, 01:55 AM
See post #2
brushlessboy16
brushlessboy16's Avatar
03.27.2009, 06:37 AM
I see two things. Is the front bearing fully seated in the diff mount? i tlooks like its is not.
Also there is some wear in the output cup to the front, you can see the Pin from the cvd sitting low in the slot.. Are the outputs hardened?
jhautz
jhautz's Avatar
03.27.2009, 08:28 AM
Yep the bearing is fully in. Nope, no wear on the outdrive. It hasnt even been run yet.
Mike will have to answer the hardedned outdrive question, but if I were a betting man Id say it is. Mike doesnt typically cut corners like that.
to make it...
or break it...
Silent...But Deadly
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.27.2009, 08:47 AM
The AE(and many others) simply have their bearings protruding from the bulkhead - it will fit all the vehicles mentioned so far in this thread with some shimming needed for the Ofna and older Kyosho and HB stuff(which use larger diffs). It won't drop into the MP9, which has very small diffs - would need slight mods to make it work.
The out drives are hardened - if they weren't, they probably wouldn't make it through a single race. The cvd drive pin is what is worn in Jeff's picture.
FastXR
03.27.2009, 08:58 AM
Will it fit in my Matrix TR with out any big issues?
Erevocanuck
03.27.2009, 07:39 PM
Will this fit the Traxxas E-revo?
03.27.2009, 07:43 PM
It will not...
Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
03.27.2009, 07:49 PM
129.99, its all over the place.
I better start saving.........that's $300+ including freight for me, damn exchange rates
I like it.......I LIKE IT ALOT!!!!!!
superek4
superek4's Avatar
03.27.2009, 11:06 PM
damn hope it's worth it, it will save d motor n less heat?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
brushlessboy16
03.28.2009, 11:42 AM
Probably no difference in heat. but yes it will save the motor from hard impacts
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
