Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Kcaz25
Kcaz25's Avatar
07.13.2009, 09:11 PM
Thanks Mark.
What about these? CLICK check the ones in post 185 as well.
Kcaz25
Kcaz25's Avatar
07.13.2009, 11:18 PM
I'm cutting some off the remaining input gear (2nd), should help, right?
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
07.14.2009, 12:19 AM
The number in a bearing you need to be smaller is the width (thickness), not the diameter numbers...bearings are sized like this: IDxODxW, and the ones you listed just have their ID (inside diameter) and OD (outside diameter) listed.
So, whatever the width of the problem bearing, just get one 1mm smaller...if the stock bearing is 5x11x5, get a 5x11x4. The hole in the transmission case where the bearing goes needs to be deeper, not larger in diameter.
-Chad
PM ME IF YOU HAVE THE BELOW:
07.14.2009, 12:39 PM
^^Yep.
Any mod to the tranny case needs to be done with abit more precision than a dremel can manage...
07.14.2009, 01:09 PM
You need a CNC mill to really get it done right... go to your local machinist...
07.14.2009, 02:55 PM
you wouldn't really use a cnc to do clean up work like this. a mill, yes. CNC is computer numerically controlled- you wouldn't write a program for a CNC for one cut on a mill. There are CNC plasma cutters, water jets, mills and other things, CNC is just how they're controlled.
I imagine with my good carbide bit on my dremel I could add 1mm to a bearing hole. It would be easy to screw it up, but I'd try it.
Chadworkz
Chadworkz's Avatar
07.14.2009, 07:09 PM
As long as you use an end-mill bit, because a drill bit won't work...and you better have a hand that is as steady as a robot, because you are making the hole deeper, not larger, and if you aren't robot steady you will mess up the diameter of the hole.
-Chad
07.15.2009, 09:46 PM
it'd be no different or harder than drilling any peice in a drill press. set the peice, set the depth stop, pull the lever. no computers or "robots" necessary.
mkrusedc
NeuMaxx
mkrusedc's Avatar
07.14.2009, 05:39 PM
Or you could just use the plastic half case...
Kcaz25
Kcaz25's Avatar
07.14.2009, 05:59 PM
Yeah that is what got a chunk knocked out of the MMM! Remember!? I think it finally did in the old fan aswell. I must have this new mounting configuration for the airflow and for the uniqueness and weight distrubution. Remember the MMM is now under the motor. The motor endbell didn't like the hit either but it took it for sure. The whole plastic case was FLEXING when landing jumps
As per my emails with FLM after they told me that it will work after me warning them that very few actually do in the real world, I'm sure they'd be obliged to fix it for me.
Chadworkz
Chadworkz's Avatar
07.15.2009, 10:10 PM
Yea, it can be done with a drill-press, but not with a Dremel. However, I would just use a 1mm thinner bearing, heh.
-Chad
Kcaz25
Kcaz25's Avatar
07.15.2009, 10:47 PM
HeY check this out I'm grinding the gear itself down and it seems to be working!
But on another note, I hate my dremel its nicd!!!!! Like 4 volts!! feels cheap, plasticy, like a toy! It last for like 3 mins! Takes like 3 hours to charge! AHHH! Does anybody have the lithium ion one? I lust after that thing!!! It will be mine soon! HAHAHA... LOL
RCM members are the greatest by the way.
07.15.2009, 10:58 PM
Don't get the li-ion dremel. It is terrible. Just get a plugin one.
Kcaz25
Kcaz25's Avatar
07.15.2009, 11:13 PM
Howdie friend! I like the profile picture! What do you mean? Anything is better than 4v nicd!!! Have you owned it? I really like being portable.
George16
Supermaxx
George16's Avatar
07.16.2009, 12:49 AM
I vote for a plug-in dremel. My wife bought me one back in 2002 and it's still working like new.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests)
