Thread Tools Rating: Thread Rating: 9 votes, 4.11 average. Display Modes
Electric Eel
06.18.2010, 07:06 PM
Started my build, finally. Sorry about the terrible pictures, but I suck at photography. The Neu 2220 fit great. The Turtle Racing easy access diff and the GH bulks all fit perfectly. Very good machining on this kit. Usually I have to file and/or grind a bit to get everything lined up. The diff cups are Phatdad 5mm pin Crossovers.
Ryu James
Ryu James's Avatar
06.19.2010, 04:42 AM
is that 2220 the same size can as the 2230? i was looking at buying a 2220 last fall for my rampage and when i called Neu they said it was shorter than the 2230 but just a hair longer than the 2215. but looking at yours i would swear its just the 2230 can but obviously with different windings.
Jammin SCRT10 Neu 1512 1y
06.18.2010, 08:24 PM
*Fap*
Andrewg
06.19.2010, 04:13 AM
Mike
Have you logged your car?
Have a think about this. At the 91% level of efficiency (most Neu 1500s and up will reach this when in the right voltage and load combination) how much change in efficiency will produce a 25% difference in heating?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
06.19.2010, 12:06 PM
Originally Posted by Andrewg View Post
Mike
Yes, I have logged my Baja on 7s and 8s with multiple gear ratios. 8s with the 12t pinion is my favorite, and this setup yields upwards of 170 amp burst rates. I have logged upwards of 4000 watts peak power output with the 12t pinion, too.
It is true that a Neu or Lehner motor in ideal circumstances may reach 90% efficiency, but this would be in very specific circumstances that will not happen very frequently if at all, and not for sustained periods in typical rc car use. Consider that the motor would need to be in ideal circusmtances, as well as the ESC, batterries, etc. - there is resistance in everything along the way(the gear mesh will cost 1-2% efficiency in power - even more in the tranny itself, the battery connections, wire, ESC, etc. all have resistence that makes achieving 90% efficiency extremely unlikely in the real world)Actual efficiency will likely be very significantly lower. Regarding heat - even if you use 90% efficiency as the baseline, dropping to 80% efficiency(still somewhat unrealistic throughout the run) would double the heat generated(so a 10% efficiency reduction would yield 100% more heat). It is very significant.
thomatrix
06.19.2010, 04:53 AM
Mike - what is the maximum lenght a motor can be and still fit?
Ryu James - I am quite sure this is not a 2230 can. I have tried to measure the space based on measurements in photoshop and from what I calculated there is approximately 114.8mm space for the motor can and the Neu 2230 is around 119.4mm long so it could not fit.
06.19.2010, 07:27 AM
AndrewG- trust Mike, and us, in trucks this size you need more motor than you do in something 50% lighter. Big truck = big motor, hence why a little S can motor being used in a maxx sized truck would fry & not be able to achieve a speed in excess of about 20mph. Since full throttle is only used sparingly usually ( due to lack of space ), the motor wont destroy the truck's driveline very easily and overpower the truck- yu just gotta learn how to tame the beast & handle the power
And Mike did state that he logged his runs with an Eagletree too.
Electric Eel
06.19.2010, 08:33 AM
The 2220 is 4.3 inches long. There is 5 inches of space for a motor on the kit, so a 2230 might fit. You would have to poke the wires through the chassis brace, but I think it would work.
As far as motor size, my experience is the bigger the better. I went to the 2220 because my 2215 was getting uncomfortably hot when running in grass after multiple packs. This was with a gearing of 58/16. Mike's kit lets me go down to 58/14. With a lower kv motor(and a larger one), I think I'm all set for bashing.
It's all good, watching a huge 1/5 scale leap around like a Savage Flux is one of lifes joys.
thomatrix
06.19.2010, 09:01 AM
Mike - Can you confirm that there is 5 inches (127mm) of space for a motor?
Electric Eel
06.19.2010, 09:36 AM
Here's a picture. 5 inches exactly.
thomatrix
06.19.2010, 09:40 AM
Thanks so much for this!
billy gunn
06.19.2010, 11:05 AM
From that pic, a 2230 would fit. It may be tight with the wires though. Once Mike gets some more kits in stock, I'll let you know. I'll pick one up for my e-baja
thomatrix
06.19.2010, 11:48 AM
I just ordered one too. I know it may be going over board but I have a 2215 and ordered a 2230 + a Lehner 3060 to try out on two bajas.
Excellent thread here btw! Thanks of all the pics and info. Much appreciated.
FG101C
06.19.2010, 11:55 AM
This thread is going to make me spend more money I shouldn't spend. My 1:1 car is freshly paid off though,
Ryu James
Ryu James's Avatar
06.24.2010, 07:36 PM
where are you buying your motors from? particularly where did you buy your lehner?
