07.25.2009, 09:36 PM
where did you get the black wheels?
Big House
Big House's Avatar
07.25.2009, 09:58 PM
Nitrohouse..I forget what the part number is but they have them.
07.25.2009, 10:13 PM
Thanks...looked all over, but for some reason forgot about them.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.25.2009, 10:28 PM
Awesome work. IDK if that chassis is strong enough, though..................
Big House
Big House's Avatar
07.25.2009, 10:45 PM
I hope it is...or at least it better be. And I hate your avatar...it happen to me about a year ago.
What's_nitro?
07.25.2009, 10:53 PM
It's definitely strong enough. I'm sure 3mm would've been fine with he top deck in place. AAMOF, you should do 3mm on top to save that little bit of weight.
Sry to hear that. I've been lucky so far. Now watch, the next time I turn it on it'll go RRoD on me! (Red Ring of Death for those of you who didn't know)
Big House
Big House's Avatar
07.26.2009, 01:37 PM
The little weight savings from a thinner top plate is more than compensated for by the fact a 2200Kv motor powered by 5 - 6s batteries will be powering this thing. Not to mention the CF chassis and top plates weigh less than the hardened aluminum chassis.
A small set back...
Big House
Big House's Avatar
A small set back... - 08.07.2009, 10:20 PM
I got the HPI 2200kv Tork motor in with fins and it is to big for the Tekno mount. I want to order Mike's mount for the GTP but I would feel a lot better with some back side support. Pushing 22-25v into this motor has to create some incredible torque so I want to maintain the best gear mesh possible. I have looked up the Flux's motor mounts, but HPI commands a premium for them.
I am sure the RC-monster mount is solid but will it hold this beast.
08.07.2009, 10:36 PM
Yes with No issues
The heart of the Beast!!!
Big House
Big House's Avatar
The heart of the Beast!!! - 08.07.2009, 10:51 PM
Here is the heart of the beast. And looks how it compares to the regular Mamba motor.
Name:	Motor Comp shot.jpg
ID:	7533   Click image for larger version
08.07.2009, 11:03 PM
FYI You might need to grind some fins off...
Big House
Big House's Avatar
08.07.2009, 11:08 PM
Why is that? I think that might give me the horizontal support i was concerned about.
08.07.2009, 11:13 PM
you generally want to allow it to flex - Otherwise chassis flex actually bends motor mount which will screw up your mesh...
Big House
Big House's Avatar
08.07.2009, 11:28 PM
The 4.4mm CF top support plates and 4.4mm CF chassis...Flex will not be an issue... that is why I want the motor locked in as solid as possible.
bdebde
That's All Folks!
bdebde's Avatar
08.18.2009, 11:17 PM
You got a total weight on that rig?
My all stock one with 6s is HEAVY. Took it out for a first drive today, suprised how nice it handles though. Only got a couple min. in, I need to set more brake on the MGM controller.
