johnrobholmes
johnrobholmes's Avatar
10.20.2009, 04:40 PM
Not sure when they will arrive, but we have them on order and should have them around the same time as anyone/everyone else. I will post when I have some tracking. :)
I talked with Mike today and he told me that he was getting a big shipment on Friday. These little beasts will be awesome for so many vehicles, I can't wait to get mine!
---JRH---
muck
muck's Avatar
11.13.2009, 01:17 PM
mine is in the mail today for my STE...
Looking forward to it..
Cain
10.13.2009, 04:49 PM
So, for a guy running 4S 1/8 buggy with say a Tekin 1900Kv motor, is this unit going to be suitable?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
10.16.2009, 08:37 PM
The 1900 draws 2/3 the current as the Castle 2650, I have done eagletree graphs on both. By my math, if the the MMM can handle the 2650, and the MMP is cable of 2/3 the current, the MMP should handle the 1900 just fine.
Area 52 Ranch Raceway
T.R.C.R.
Pdelcast
Pdelcast's Avatar
10.17.2009, 12:25 AM
Careful, that's an assumption that may not be necessarily true. Just because the Kv of the motor is lower, doesn't mean that the current draw will be lower. Gearing has just as large an effect on current draw than Kv.
At a given voltage, and a given truck/car, it will still take the same number of watts to drive at a given speed -- and therefore the same current.
Patrick
Patrick del Castillo
President, Principle Engineer
SpEEdyBL
SpEEdyBL's Avatar
10.18.2009, 12:40 AM
Patrick
Very true, but the 1900 i am refering to is effectively a 1512 1.5Y with twice as much resistance. Also, out of curiosity, I decided to gear the 1900 20/46 in my 8ight to match the theoretical top speed of the 2650 geared 14/46, and the 1900 was slower, was sort of sluggish, and ran cooler, meaning it used less power. Actually, I have noticed that the MMM heats up the most when using low throttle, i.e. racing on a track where the average speed is 15mph, vs. bashing out in the street or a grass field at 40 mph. With a 1900, i have to use more throttle input to get the same speed, causing the esc to run cooler as well. Those were just my experiences that led me to assume the 1900 on the MM Pro was ok. In fact, I don't even use the MMM fan with the 1900. I don't need it and the connector and solder joint to it broke off anyway. It's also a V2...
T.R.C.R.
Pdelcast
Pdelcast's Avatar
10.18.2009, 01:42 PM
In most applications, yeah a 1512 1.5Y (1900) will draw less current because it generates more torque. But don't think it's the resistance -- a 1512 1.5Y is just as much a dead short from phase to phase as a 1512 1Y (2650...)
Resistance in these motors is so low that it doesn't have any significant effect on current draw.
Pdelcast
Pdelcast's Avatar
10.19.2009, 12:39 PM
You could make the resistance 50 times as much -- still wouldn't have any real effect on current draw.
You have to realize these motors will pull whatever current they need to produce the torque you ask of them.
A 1512/1.5Y has about 6.5 milliohms of resistance. With a 20 volt battery, the stall current is about 3100 amps.
A 1512/1Y (like the Castle 2650 motor) has about 4.5 milliohms of resistance. With a 20 volt battery, the stall current is about 4400 amps.
So you see, resistance doesn't matter ONE BIT. It's about torque generation -- which is gearing, tires, terrain, vehicle weight, etc.
The motor will draw whatever current it needs to generate the torque that is asked of it. A 1512/1.5Y when incorrectly geared can easily draw over 1000 amps.
All of these types of motors don't have enough resistance to have any real effect on current draw.
10.13.2009, 05:34 PM
As long as the buggy is lighter and gearing is 30-35mph, it should be fine.
Cain
10.13.2009, 08:36 PM
Buggies a Hyper 9E. would be using a Tekin 1900Kv motor with this geared in the low 40mph since that is common gearing for the tracks I run at.
Unsullied_Spy
Unsullied_Spy's Avatar
10.17.2009, 05:26 AM
Is it a bad idea to run the CC 2650 on the MMP? I have 2 Hyper 7s and both are in need of ESCs and I'd like to try out the Pro, but the 2650 is going into my offroad basher and the Medusa is geared up to the point that it gets my MGM hot.
ravin
ravin's Avatar
10.17.2009, 08:28 AM
I was thinking of the same setup in a slash 4x4 on 4s.The slash is suppose to be about 1/2 the weight of a E-REVO .... (geared for low 40's).
E-revo mmm 1518 6s
Rustler mmp novak crawler(17.5 stator) 6s
Slash 4x4 1512 1800 mmp 6s
E-maxx 1350kv mmp 6s
Summit VXL
Stampede 4x4 Rx8 1400 mmp 6s
Unsullied_Spy
10.17.2009, 08:47 AM
In the Slash it should be fine because it's so light. I'm a bit worried about running one in my Hyper because it's rather heavy.
bdebde
That's All Folks!
bdebde's Avatar
10.17.2009, 01:49 PM
If your MGM is getting hot, it would be a step backwards to go with the MMP; you need the MMM or add the fans to the MGM.
Unsullied_Spy
10.17.2009, 06:13 PM
That's in my over-geared onroader, I'm thinking about my offroader but worried that the 2650 may be more than the MMP can handle.
