i pwn nitro
05.26.2009, 02:47 AM
DEANS FTW!!!!!
never failed me yet.
i chose to use summit axles over the CVD's cause CVD's have a doggie bone at one end...and this always pops out on me
where as the summit shafts are technicaly a CVD at both ends.
we'll see how strong they are
trying to scrounge myself a hyper 7 diff too :P..casue the traxxas one with 500k oil is not thick enuff methinks (but i never re-build it  )
shaun
05.26.2009, 08:06 PM
Looks very pro MC. :)
Question,
do you compensate for the CF plate on top, and the one underneath you placed earlier, by using longer screws for the rear shock mount?
Guelph, Canada, eh!
05.26.2009, 09:07 PM
Question,
absoloobly  I use M3X.5X45 mm cap head screws 12.9, they stick out the bottom like I showed in post #32 and I lock them up with M3 nylok nuts from underneath the chassis.
05.26.2009, 09:34 PM
Ahh right, I remember that. Man that thing is going to be bullet proof, what I like most is that it just looks so professional.
I copied your idea of the rear skid plate made out of cheap sheet metal a while ago, works great.
Today I was looking to make one for the front to, as it is needed most there.
It ended up nice, and without any drilling into original parts. (I wanted to keep stock parts undamaged so it'd be easier to sell later. I have an E revo, and want to go BL later... money you know  )
Guelph, Canada, eh!
Deans deans deans deans -
05.28.2009, 01:50 PM
I'm dizzy from the soldering fumes
A little thing I do when I solder Deans plugs. Although I am very careful and plan ahead, on occasion, I have to keep the soldering iron tip longer than I should on the Deans' metal tab making the plastic start to melt and the tab moves and becomes crooked. This results in a bad connection or no connection at all. You know, you suddenly have a little twitch and the iron tip moves with the wire and you try to reposition it, it only takes a couple seconds but that is enough to over heat the plug's metal tab.
Some say to connect a male plug into the female plug you want to solder wires to and vice versa. That extra plug absorbs a lot of the heat and often makes for a poor soldering job, cold solder.
So here's my trick, I stuff tiny pieces of hard wood in the female plug I want to work on. Those pieces of wood have been sanded down carefully so that they fit snug but not tight. The wood does not absorb heat and it holds the plug's metal tab in place in case something happens and the plastic starts to melt. For a male plug, I took a scrap female plug and yanked the metal tabs out oh it and replaced them with the wood pieces. This holds the metal tabs of a male plug in place in case the plastic starts to melt. Easy and effective, it made the job much easier.
Soldermaster Extraordinaire
05.28.2009, 09:31 PM
...I have to keep the soldering iron tip longer than I should on the Deans' metal tab making the plastic start to melt and the tab moves and becomes crooked. This results in a bad connection or no connection at all.
You should try a more powerful iron, or a soldering gun. I use my 230W gun to solder Deans and 5.5mm bullets. I let it heat up for a bit so when I put it on the Deans' solder tab it heats/solders so fast that the other end barely gets hot. It also helps to tin the wire/tab just before soldering it so they're still warm and the solder re-melts more easily.
05.28.2009, 02:09 PM
And that my friend, is another reason I switched everything over to 5.5mm bullet connectors....
NeuMaxx
05.28.2009, 02:44 PM
...Anderson PowerPoles...no soldering necessary!
Guelph, Canada, eh!
05.28.2009, 07:45 PM
Thanks for the suggestions. 5.5 bullets, Deans, Traxxas, Anderson PowerPoles, EC5s...  I like how everyone agrees on one good connector
roofles.
05.28.2009, 09:04 PM
I know right?
I thought about PowerPoles and Deans when I first started RC.
Then, just a few eeks ago, I started thinking about EC5s.
Then, a few days ago, I'm thinking about TRX connectors.
I think I'm just gonna stick to Deans, but just gotta switch over all my HobbyCity plugs to some real Ultra plugs.
05.29.2009, 08:21 AM
Have you noticed any difference between them?
roofles.
05.28.2009, 10:02 PM
230W...
What the...
Link?
I only have a puny 60-80W iron..
Hmph.
05.29.2009, 02:13 AM
I would give you a link but Sears is updating their website again... :/ It's the Craftsman 150/230W soldering gun. #54046
Guelph, Canada, eh!
05.29.2009, 08:57 AM
I have a very similar gun that has the same wattage as the Craftsman but by a different company. It has been sitting in it's box somewhere ever since I bought my Hakko. I find my Hakko and Weller soldering stations much more efficient and easier to use than a gun. This is my preference, yours is the gun and that's fine too.
roofles.
05.29.2009, 09:57 AM
Here you go:
http://www.sears.com/shc/s/p_10153_1...54046&sLevel=0
