Anyone else got these?
This 10awg wire is just over kill... You need right tools to solder that big wire, i used pyropen without any nozzle to heat up bullet connector and that way i was able to solder connectors, without damaging battery with heat.
I use a 300watt soldering iron for stuff like that, 5 seconds warm up and it can melt through anything, and it's like you said, easier on things like batts, speed controller, etc. Get in and get out.
I think everything should be coming with 10awg wire now IMO. Add that extra edge of voltage holding ability, especially on LV setups of 4s or less. But it just won't heat up and will also act as a heatsink to suck heat away from batts, ESC, or motor. Just my two pennies.
