Well its just turning it around if you use stock centerdiff, otherwise you might need to grind center stiffner abit.
But be aware that front brace limits motor and gearing just little, if you use 36mm motors and 52t spur, then your smallest pinion would be 11t. But its same even if you have motor in back.
