FastXR
06.25.2009, 02:45 PM
His name isn't SUICIDEneil for nothing.....
06.26.2009, 07:12 PM
You are quite correct, the charger does ask you to confirm you are (in this example) charging a 5s lipo, but it only 'sees' a 4s lipo due to the low-voltage issue. In which case, my charger will charge the pack as a 4s lipo once you press the OK button (it will ignore you telling it you have a 5s lipo hooked up, even with the balance plug connected). That way, all the cells are charged (since they are in series and the balance plug is only for balancing during charging) and you just have to abort the charge once all five cells reach ~3.6v to give a total of 18v. Then retart it with the correct setting of 5s and they will all charge in unison until they hit 4.2v.
I know it kinda sounded like I was saying 'charge 4 cells up until they reach 3.6v/ 4.2v, then stop it & start it again until they all say 4.2v including cell 5', but what Im really saying is 'charge all 5 cells until they get to 3.6v whilst ignoring what the charger tells you about pack size/cell count, then stop the charge and restart it as a 5s pack until its fully charged'. **breath**
Finnster
KillaHurtz
Finnster's Avatar
06.26.2009, 07:28 PM
okey dokey ;)
