nitrostarter
nitrostarter's Avatar
06.30.2009, 12:42 PM
Would be fun tho. And then you wouldn't have to worry about gear reduction...
N. Rustler conversion
06.30.2009, 12:46 PM
No no- I have a minibike and a pocketbike (project) and a honda xr200r, but that's unrelated.
07.06.2009, 12:13 PM
Got a little more done...
Here's the engine:
Motor mount almost done- needs to be welded on to the stiffener plate/chassis:
And the rear sprocket mounted to the wheel, this turned out really badly because I had to do this weld quickly as to not warp the sprocket past the point of no return and the fact that the wheel and sprocket are lousy steel, AND I also couldn't remove the freewheel, not press fitted or threaded... so I had to weld it to itself so the motor can help slow the bike down at idol:
07.10.2009, 10:19 PM
Today, I went to a industrial salvage yard and a lawnmower shop. Picked up a #35 9t 5/8" sprocket for use on the clutch, a #35 28t 5/8" sprocket to use as the primary on the jackshaft, a #35 20t 5/8" sprocket to use as the primary on the jackshaft if the bike isn't quick enough, a #40 9t 5/8" sprocket to use as the secondary on the jackshaft, which will run to a #40 40t sprocket mounted on the rear wheel, pictured above. I also bought some fuel line, #35 and #40 chain of the correct widths, and some 5/8" ID 1 3/8" OD flanged sealed bearings for the jackshaft. I have everything except the twist throttle to get this running now. Hopefully I can get it all together by sunday night, providing I can get a full day's work in on sunday. I will get pics as well.
07.11.2009, 12:09 AM
Anyone?
Snipin_Willy
Snipin_Willy's Avatar
07.11.2009, 12:38 AM
Anyone what?
Sorry, I was too busy looking at that lousy weld job
Get it running. I wanna see some sparks.
07.11.2009, 12:49 AM
The weld is better than the pic looks actually. And i had to weld the freewheel together because I couldn't remove it, and need the engine to help slow the bike down, as the drum brakes aren't worth the $5 I paid for the bike roller...
07.13.2009, 11:27 AM
More progress.
Goodies:
Clutch and its sprocket:
Welded some jackshaft bearing mounts and the stiffener plate:
Fitting motor mount with welded on washers:
Motor mount complete:
I also did alot more, but my hands were so dirty I didn't want to take my phone out to get pics...
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.13.2009, 12:13 PM
Did you put the chain on a granite countertop? Was your mom happy?
07.13.2009, 12:42 PM
Not a countertop... Just a piece of marble my dad had lying around.
Modding_out
disturb'in the peace......
Modding_out's Avatar
07.13.2009, 08:19 PM
Remove or disable the Governor in that bike and you be hitting 40+ no joke.
I can't help you on the tork department, but the briggs is going to have less tork cause it's stock and a flat head. stock to stock (omitting Governor removal) ohv winns every time. but modified.....flat head rules.
Don't call it a piece off crap if you don't know what your talking about(I'm not disss'in you man, I'm just saying so no hard feelings) as far as mini bikes go( ive got several bikes, they keep spawning in by garage ) there pretty nice.......... go to this web sight http://www.oldminibikes.com/ it will rock your world when it comes to mini bikes......
Ever hit 100 MPH with a bike that has a 4.5' wheel base?.........Thats what I thought, rock on that mini man!
BTW thing was directed at your Baja mini bike.
J57ltr
07.13.2009, 08:54 PM
Seems like it's geared for about 20mph. assumming 9K at the motor and a 10" tire. I came up with a 13.8:1 ratio without your maybe sprockets if I read it right.
Personally I would at least support the rear of the engine or put a gusset ot 2 in the motor mount. And I don't know about the clutch it's probably a little light for the application without a lot more ratio or a varaible trans, looks like a fun project.
Might look into something like this:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=290219663298
Or this:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=250337233246
Both have a clutch bell built in.
Jeff
07.14.2009, 05:06 PM
I'm geared for about 23mph. Thanks for the suggestions guys, and yes the motor mount is gusseted.
07.24.2009, 01:50 PM
I figure I should update this thread. IT RUNS!!!!
Well, it's not finished, but it turns the rear wheel...
Here's the secondary jackshaft sprocket. Had to be heavily modded to mesh with the chain properly, keyed and mounted to the jackshaft:
Jackshaft completed:
Here she is:
Ignore the fuel tank how it's mounted. Just did that so I could test the motor, and make sure I had no binding.
I also made some seat stiffeners, but I will get pics of those tomorrow or sunday. I hope you enjoy it.
J57ltr
07.24.2009, 07:13 PM
That looks great! Cant wait to see it completed. Are you itching to ride it?
Jeff
