aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.07.2009, 12:24 PM
LOL, 16S would be nice if I had the controller for it.. heck, I'd run 20S if I could...
I rigged it up so if I do brake anything it will be easy to replace with stock Duratrax parts. And it's geared for 57MPH on 12S and 38 on 8S.... most/all of the parts are from the original Duratrax part... The motor mount was so easy to make.. I'll take a snap of that maybe tomorrow for you guys.. Pinion, I used the 14T 10mm bore transfer gear from the firehammer.. and for the 6mm ==> 10mm sleeve I used the support inserts which supports the petrol engine.. Worked out perfect!! I'd just have to bore it out to 8mm when/if I put the 2280 in...
Yeah, I have the front wheel disc brakes, I haven't mounted it on yet, only the discs.. I'm using the rear disc brakes on the shaft.. but I will eventually go to all around disc brakes to save my transfer gears and Differential...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
07.07.2009, 08:45 PM
Aye, nice work on the conversion Aqwut- she's a real beast.
07.07.2009, 09:38 PM
Seems like that KB will fry at 50mph...
lydiasdad
07.07.2009, 11:28 PM
I have several runs on a kb45-8xl in my 1/5 scale buggy and am happy with the power, however my temps are high on the motor. It does make impressive power though. Nice conversion by the way, pretty snappy on 12s
aqwut
aqwut's Avatar
07.08.2009, 12:01 AM
Thanks guys.. the motor may fry... but it hasn't shown any sign of being demagnetized yet.... fan really helps with the heat, going to put a tube over the motor to see what happens.. it still runs after 10 minutes of play... That KB-45 is not the most efficient motor by far.... but if you could find a way to cool it down, it works like a charm...
aqwut
aqwut's Avatar
07.19.2009, 11:33 PM
Well, KB45-17XL runs great on 8S... yesterday at the track, I ran 12S and forgot to turn the fan on... Motor reached temperatures of 109 Deg. C. Of course, rotor was demagnetized and pooched. Here are some pics of the mounts.. it was easy..
Here's a video.. of it for fun, with the 2280 and 4S ... ESC Temp was 40 Deg.C , Motor 44 Deg.C and Batteries were 57 Deg.C a bit too warm.. Wait till you see the 2280-6 HA on 8S... :)
http://www.youtube.com/watch?v=dV51RnoBrGc
jsr
07.20.2009, 01:56 AM
Wow, the FH flips over on 12s!...that's some serious power. It looks like even on 8s, it has plenty of power for nice acceleration and speed. In your videos, you seem to run for pretty short periods of time. What is your runtime on the packs you're running? Also, what temps are the ESC and motor hitting if you run until the packs are dead (hits LVC)?
Thanks.
aqwut
aqwut's Avatar
07.20.2009, 07:56 AM
My text was off.. on the picture.. The batteries I was using were 3700mAh.... and used two of them, that whole run drew the whole two packs.... Just got the batteries charged, and it drew 3500mAh per pack....
Byte
07.20.2009, 08:42 AM
That looks very nice! Do you got an other vehicle so I can see how big it really is? (My LST also looks small on pictures, but if I put my Rustler VXL beside it the LST is huge )
And I've got another question; where do you get that aluminium? I've been in several stores in the Netherlands an Germany but I can only find damn tin aluminium. I have to use steel to make my motormounts. But I could only find steel with holes in, that isn't that cool...
So could you/anyone give me a site where to order that aluminium?
Thanks!
aqwut
aqwut's Avatar
07.20.2009, 08:57 AM
Thanks!
I get all my aluminum from eBay... I just buy angle aluminum and 6061 sheets.. It's very cheap... You should have a lot of aluminum over there... Thyssen Krupt is a huge company in europe... try buying from them, I'm sure you could buy aluminum from any fabricator..
aqwut
aqwut's Avatar
07.21.2009, 12:06 AM
Here's the picture of how I made the mount..
