Basketti
01.13.2006, 12:50 AM
if you get the 9xl you could gear it high as and it will probably still wheelie! and the top speed would be fast as!!
lydiasdad
01.13.2006, 01:02 AM
Ok, say you have a truck. You put a xl motor in it, gear it so the wheels spin at 50mph. Then you put a s motor in it, gear it so the wheels spin at 50mph. All things being equal, will both setups pull the same amount of amps?
MetalMan
MetalMan's Avatar
01.13.2006, 09:52 AM
They won't pull the same number of amps. They might be close, but the XL could pull more simply because it weighs more, or the S could pull more because it can spool up faster (lighter weight rotor).
lydiasdad
01.13.2006, 10:30 AM
Thanks for the replys guys. Such fast responses too, awesome forum! I guess now all there is to do is try it and see. I will be using 2.2" wheels also so that should drivetrain stress. I will start at 12 cells and work my way up until something breaks. Then I will have "enough" power.;)
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
01.13.2006, 08:36 PM
As long as the motor resistances are the same, overall power should be about the same.
Area 52 Ranch Raceway
T.R.C.R.
