123-126F is luke warm on a motor. My truggy is pushing 175 after 20 min mains of conservative driving. And I'm running a 1515 2.5D tekno neu. Ambient air temps were quite high though as well as humidity levels.
3s on a 2700kv motor is enough to race with. It pulls more amps than a lower KV motor on higher cell count, but that's where it's getting the power from. Until you're seeing upwards of what I'm experiencing, I wouldn't go to 4s unless you had a lower KV motor.
hmm...i guess it's a 3S for this motor and the race, then.
One would gear down when using higher voltage, otherwise you will be spinning the wheels to fast to control the truck.
I think your genral issue is that the motor you have is too fast for 4s & racing (4s & bashing would be fun though), yet on 3s it will be pulling quite a few amps if not geared conservatively; most people tend to run the 1515 1y on 4s, or the next slowest motor option on 4s/5s.
I would stick with 3s if its working good for you, just gear as required to get your desired speed and 'oomph' levels vs temps.
ah...well, I guess it's best that I stick to the 3S packs. Guess I'll get me a couple of the TP 40c packs.
If you match the motor kv to the voltage, and aim for the 30-40,000rpm range, then 'power' will be pretty much even once you take into account gearing for the same speeds.
Anyways, the PolyQuest 3s lipo is pretty beasty, but I would look into the new Hyperion Gen3 packs (Mike only has 5s packs at present), should be able to find them for sale somewhere- Mike wont mind as he doesnt sell them
I think I may give it a shot, then. Need to find the $$$ for the motor first, though.
what about the PolyQuest vs. C-Tech RC packs? I've been hearing about the G3 packs, but I'm trying not to break the bank in my purchases. At least not yet...
I'm liking the C-Tech for it's budget, but I'm also liking the PQ for it's capacity.
Anyone have feedback on the power delivery comparison for the two packs?
I only have good things to say about my C-Tech 25c packs. I run them in my truggy and they have awesome power.
I'm not sure if you wanna go with 4s battery or whatever but a lower KV motor can really open up your battery options.
