bryan
bryan's Avatar
08.22.2009, 10:16 PM
so i found time to crack the seal on this battery ,and guess what? there is absolutly no f$ing way anything can be wrong idont understand how one battery can charge fine and this one flips out.all connections are good
scarletboa
scarletboa's Avatar
09.04.2009, 12:13 AM
that's what i thought about my zippy pack. i gave each little wire a gentle tug, and sure enough, the yellow balance lead came loose and once soldered up, problem solved.
08.23.2009, 10:57 AM
Well, if thats the case, then I would say either the metal contacts are dirty or damaged on the charger probably, since a sepertae test of the lipo revealed all the cells to be pretty well balanced. Perhaps a little inspection of that is in order... (turn it off though of course first).
