Guelph, Canada, eh!
10.18.2009, 11:04 AM
Originally Posted by miniGranis
Is anyone intersted in selling a 1/8 center diff that will fit a nitro (3.3) tranny ?
I dont have the skill, stuff or time to do one myself.
I could part with the ''CowboyRay'' CD I have. I updated it with shafts to run the rear brake so it's ready to go inside a 3.3 Revo tranny. PM me if you're interested.
10.18.2009, 06:25 PM
That cd w/the carbon fiber is real nice...I wish I had the skill to perfectly cut a perfect circle like that! Well done! =)
There is no help for me... I'm addicted to R/C
10.20.2009, 04:21 AM
hahaha cool stuff man, I read your first part an yes the other guy was me. I also read about crashes idea and then ran with it but in a little different direction.. Also if you look in the thread Outlaw ran with the idea aswell and actually fitted a Robinson racing gear on the center diff, last time I chatted with him he said his thing is indestructible..
I have yet to follow suite with the Robinson gear as I was busy on a few other projects, also I did find that the plastic gear could not hold up to actual race conditions.. IE hard braking and acceleration while coming of jumps.
Here's the thread,
http://hdrcvideos.com/forums/viewtopic.php?f=42&t=17886
10.20.2009, 04:32 AM
Here is the other thread,
http://monster.traxxas.com/showthrea...42#post3953042
BTW I just remembered what I was talking about before LOLOLOL
if you read one of my last posts I was intending to make the "CAP" of the CD out of a Kyosho plastic 44T spur, it would be super cheap and super easy to do. You just use the same principle as the studs but replace the hardened steal with plastic :)
I already checked the bolt pattern and there the same for the kyosho and losi.
Originally Posted by shaunjohnson
you dont understand how close i was to getting a losi smart diff for conversion, same principle just a little more $.
hope to have smart diffs all round one day i think
it has been done and works really well, outlaw LST2 did it and if I remember right snagged him a 1st place finish.
http://www.youtube.com/watch?v=7OGBbpu6tG8
Guelph, Canada, eh!
10.20.2009, 09:27 AM
Here he is, the ''post man''.  I'm glad you joined this thread. Your post idea has been working really well on my CDs and made it so much easier to make them. That plastic cap idea is interesting, it will have to be tested to see if it is strong enough. If it holds up, it would make the CD lighter which is good. That LST2 from outlaw looks awsome on the track.
10.20.2009, 03:49 PM
That plastic Kyosho gear/cap would have made my life so much easier!!!!
Guelph, Canada, eh!
10.20.2009, 10:45 PM
Yes if that gear is strong enough to make a cap out of it would be a cheap alternative and easy to work with. Although, $27 plus something like $7 shipping is not very expensive to get a complete LST XXL diff. All you need after that are the Traxxas shafts and a Traxxas output gear which you still need even with that plastic Kyosho gear.
10.20.2009, 11:50 PM
hahaha waddup guys, only thing that I would do different with the plastic gear is use 4 posts instead of two and I know you cant see it in my pictures but there is actually four posts there.
i pwn nitro
10.21.2009, 06:17 AM
well my LST diff is done..the mk1 anyway lol.
i have special tallents  so it binds due to an off-center pin hole i drilled, i'm gonna leave it for now cause i just wanna use it then go back and fix it, then make mk2 from the other diff
i pwn nitro
10.22.2009, 02:31 AM
hehehehe...
even my uber crappy center diff went epicly today!!
goes to show that even the biggest crappiest version of the mr-crash diff is idiot proof
10.25.2009, 12:01 PM
Does it have to be an XXL diff? Because I already have a few Muggy diffs laying around..I would rather just use one of them and save some money
Guelph, Canada, eh!
10.25.2009, 01:14 PM
No it doesn't have to be an XXL diff. I use that one because I like the metal inserts in there. But I have made center diffs using Losi LST2, Ofna Hyper 7, Thunder Tiger S3. I am sure there are many more diffs from other manufacturers that can be used. And you don't have to start with a center diff to make a center diff. An ordinary front or rear diff can be used as the ring gear would be modified to become a cap just like a spur gear from a center diff would be. After I modified spur gears and ring gears to make diff caps, I can say that the ring gear from a diff is easier to modify because there is less material to grind off than a spur gear.
10.25.2009, 02:22 PM
Thanks mc...btw when you said you like the 'metal inserts' are you referring to the bevel gears or what?
i pwn nitro
10.25.2009, 04:42 PM
oooooooohhhhhhhhh
i thoguht ALL LST breed diffs had them metal inserts crash
was confuzled as to why my lst diff didnt have any
Guelph, Canada, eh!
10.25.2009, 05:25 PM
The LST XXL diffs I got on ebay all had the Team Losi Heavy-Duty Differential Case which use metal thingies for the shafts of the spider gears. These diff cases are the same cases used for the Losi SmartDiff. The LST and LST2 diffs I worked with used the stock Team Losi diff case.
