eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
09.09.2009, 02:00 PM
that is what happened just now with ben's MMM. he had a "super clean" setup where no wires can be seen, and when his MMM detached from the esc mount in his eight, they got yanked right out. have at least some slack between the RX cord and where it's tied down so that it can hit the body and dissipate most of its momentum.
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
V0RT3X
Muggy love
V0RT3X's Avatar
09.09.2009, 03:18 PM
Just get a TRX mount for the MMM. I have mine secured with dual foam pads and screwed down with the mount(on an erevo though)
09.09.2009, 08:24 PM
But how exactly?...
I use the Erevo esc mount on my gmaxx, and the esc doesnt move a millimeter- a foam pad underneath adds some cushioning, whilst the rock solid mount prevents the wires from gettgin yanked or tugged at.
What you can do is add a little clearance to the esc case where the rx and switch wires exit, that should releave the pinching issue; adding thicker wires will only make it visably worse (tight spot to start with afterall).
I will agree that there have been plenty of people with worn through insulation in the past, and it is caused by the poor wire routing and sharp edges of the pcb; I just think that there arent too many other ways to route the wire inside the cramped case, but as Linc pointed out, you can make a few tweaks to alleviate the problem. I myself just enlarged the opening for the wires to exit the MMM, and they've been fine for 2 years or so (MMM v1).
