redshift
RC-Monster Square Tube
redshift's Avatar
09.09.2009, 10:31 PM
You know you could get a 383 crate motor for about 1/3 of that, buckets o power. If it was nose heavy you could just put another gas tank in the tail.
But where to put the radiator?
Good luck man, I can't even handle the RC version...
TexasSP
Something, anything, nothing
TexasSP's Avatar
09.10.2009, 01:04 PM
Planes don't work that way and a crate 383 is not approved by the FAA for airplane use. You can't put land vehicle logic into an airplane. You also have total airframe weight capacity to worry about and using a fuel tank to balance weight is bad because fuel is not a constant.
The rotary engines are THE motor for light sport aircraft like that and for a reason.
The plane he has will also have to be inspected and FAA approved before flight. The flying world is just a whole different animal than the way ground transportation works.
www.cubicle101.com
J57ltr
09.10.2009, 01:58 PM
Actually you can put a car engine in an airplane I have seen it done on.
http://www.sccoa.com/forums/showthre...light=airplane
I have even seen Wankle engines in homebuilts. The Lycoming and Contential engines are glorified VW engines (except the heads do not come off, you slide the entire "Jug" off).
your gonna use cherry max rivets? a GOOD peunmatic will be around 900-1k and well the manual ones are a PAIN in the rear...... get ya a rivet gun an assortment of bucking bars and rent you a little mexican kid and have some fun!
I was that little Mexican kid...
Jeff
TexasSP
TexasSP's Avatar
09.10.2009, 04:02 PM
My point was more to illustrate that it's not a simple drop in where as buying the proper setup will be the better and less expensive route in the long run. Not too mention that you really need to stick with the type engine the plane was designed around.
www.cubicle101.com
J57ltr
09.10.2009, 09:19 PM
You are right, but the statment that a car engine cannot be placed in a plane is incorrect. There are lots of car engines that make into experimental homebuilt planes, including small block Chevy V8's. I don't know what rotary engine you are talking about, did you mean Rotax? The guy that put the 3.8L supercharged V6 engine out of a Supercoupe in his plane (don't remember what it was) came to our board to ask some questions, I told him that I wouldn't recomend it because it's not a reliable engine (or engine managment system for that matter). I don't remember what happened with the project.
Willy,
What type of time frame do you think it will take you to get it finished? I remember one of my Dad's friends had a Long EZ when I was about 12 or so and I thought that was the cats pajamas. I really like the "new" kits they have out now for the sport flying segment. I know it's probably going to be a few years before you get done but that's what hobbies are for. Have fun with it, a lot of it is going to be a PITA and frustrating, but the fun of flying will make up for it.
Jeff
rootar
rootar's Avatar
09.10.2009, 12:14 AM
what kind of tools are you looking into william?
Snipin_Willy
Snipin_Willy's Avatar
09.10.2009, 12:46 AM
Because I'm building this from a kit and not a scratch build, minimal tools are required. My dad who is handing his potion of the kit over to me has everything and then some to complete the entire build. I will pick up my own set of clamps, levels, squares, and measuring devices but the rest of the things like rivet puller (manual or peunmatic), bur files, smooth edge tin snips, clecos....I can borrow it all from him as he isn't going to use them and he bought them specifically to build the plane with. As soon as I can finish the work table I'll go and pick up what he has and start working on the fuel tank install, and getting price quotes for the fuselage kit and options I want. Most likely I will have the plane close to complete before I have my sport pilot cert.
rootar
rootar's Avatar
09.10.2009, 01:27 PM
rootar
rootar's Avatar
09.10.2009, 02:55 PM
well a little american kid wouldnt have the drive or focus to concetrate and learn how to properly buck rivets and tell him when to stop....
J57ltr
09.10.2009, 03:00 PM
I didn't seem to have any trouble.
Jeff Garza
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.10.2009, 03:03 PM
Awesome new hobby dude, Looks like a great way to spend the spare time and reap the rewards when it's done. Enjoy and be safe.
I myself have never flown in a plane, However I've ben in a Heli a couple dozens of times.
Snipin_Willy
09.10.2009, 03:33 PM
The rivets for the kit are a particular brand of blind rivets, which my dad already has the gun for and a decent manual rivet puller for. I'll pick those up from him with the rest of the stuff.
I'm thinking of putting my training off till I get the ane finished. That way I can train and solo in my own light-sport to get my certificate.
TexasSP
TexasSP's Avatar
09.10.2009, 03:55 PM
Are you going for the light sport license only? My father-in-law just got his last year. He has a teknam(sp?) light sport plane that's from Italy.
www.cubicle101.com
redshift
redshift's Avatar
09.10.2009, 05:12 PM
I was joking Tex.. whole 'nother set of standards, reliability issues I know. But I would like to see a giant outrunner in that thing!
Lipos would set him back a bit I reckon....
TexasSP
TexasSP's Avatar
09.10.2009, 09:48 PM
Cool deal, I missed it, went over my head. I have been to busy trying to take a "crash course" on a bunch of plane terminology lately and have been overexposed to general aviation lately so my meter must be off.....
I have also had to catch up on airplane engine breathing at different altitudes manifold pressure, and all that kind of junk. Couple that with some quick avionics lessons as well as wait and balance calculations my brain is on overload.
As far as the rotary I meant rotax and I am sorry. My father-in-law spent about a year researching light sport aircraft before he bought and rotax engines were the standard across the board.
www.cubicle101.com
