I have only ran a fan on one setup.
I was pushing that though.
I think exposed heat sink is not a bad idea.
As long as not to much foreign materials went into ESC.
Rc-Monster Buy here
i'm only geared for 40mph, 17/65 on an e-maxx tranny in a revo.
my peak amp spikes are only 70A and i can barely get that much power to the ground regardless.
it's all about the Watts required!
25.4v from a 6s peak voltage x 70A for 40mph = 1778W
16.8v from 4s peak voltage to attain same speed still requires 1778W of power to get that kind of acceleration to that speed.
so 1778W / 16.8v = 105.8A in theroy.
all in all, more amps = more heat
hence higher voltage is better for temps, wanna run 60mph but getting too hot?
try running 12s, same principle.
if you need your fan to be on all the time then if it fails then you are fecked!! no backup plan or anything, least if my fan were to be broken, i'd still be able to finish the race and hopefully find the dead fan before it was needed by the ESC.
I have been thinking of removing my MMM case altogether, and submersing the ESC in a bath of silicone fluid. I haven't done it yet as I cannot find a clear plastic sealable box in a suitable size for the ESC. This will keep it cool (and I could add another heatsink to the outside of the box), and make it waterproof.
Has anyone done this? I want the clear box so that I can see the lights on the ESC.
Troy
I am now free to exercise my downward mobility
