Popoxx
Sapere aude
Popoxx's Avatar
08.09.2010, 10:33 AM
OMG, These have nothing to do with the bearings.
Look at the old carriers you removed, on the back where the threaded part of the pivot ball where it comes through the back there is a metal ring(very hard to see, same color as the black plastic) must be removed and installed on RPM carrier to prevent the balls from popping out.
I read the instructions included with the updated 5334R Traxxas axle carriers and it's said these rings are bearing adapters required only if you use the inner bearings of the old 5334 Traxxas axle carriers which are smaller than the inner bearings of the 5334R model.
RPM use their own design for their axle carriers so I don't understand why you want I use the bearing adapters with these carriers
One of my pivot ball pops out my RPM axle carrier because it suffered a lot during the skate park session. It's not because I forgot to use something.
Yes freeagent there was an update, a bit old by the way . The axle carriers have been reinforced around the pivot ball holes with built-in alu rings. Links above.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.09.2010, 10:40 AM
Yes a update, same part number but w/a X on the end.
The difference is the steel ring.
""One of my pivot ball pops out my RPM axle carrier because it suffered a lot during the skate park session. It's not because I forgot to use something.""
Uh, yes you might have. The steel ring goes on the outside of the carrier to keep the material from expanding to keep the friggin' inside.
freeagent
It is like shreading $100 bills..
freeagent's Avatar
08.09.2010, 11:03 AM
Golden Horizon carriers are the bees knees, incase you were looking for something new to try out
MBX5T ProSpec|MMM/2200kv|16/46|Hitec 7955TG|KingHeadz|Badlands|5+6s
MBX5R|BCE|MMM/T8-2250kv|15/46|JR9100s|Jammin BB's|Badlands|4+5s
08.09.2010, 11:13 AM
Sounds like these steel rings are real handy when you have things popping out and you want then to stay put. Should we send some to Harold so that Hippie will stop popping out the back when the "action gets intense"?
08.09.2010, 11:16 AM
I ran alot of traxxas products and gave up on anything other than the steel pushrods/tierods. I broke everything and anything other than the steels, which I would bend, but could straighten them.
I do like the rpm true track setup, had that on one of the revos. Nice. Want to put it in the center of my 6x6 maxx based truck.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.09.2010, 02:35 PM
Why do you guys think these rings have anything to do with the friggin' bearings ???
They go on the back of the carrier where the fookin threaded part of the pillow ball comes through, they prevent the ball from popping out the backside.
Drivinfast247
08.09.2010, 03:41 PM
Then why does the kit come with only 2 rings? Wouldnt it come with 4, one for each pillow ball? Im not arguing, Im asking.
08.09.2010, 03:42 PM
Those 'rings' are bearing spacers/ adaptors, not the same thing as what goes on the back of the pivot balls.
Dont worry Bondo, I know what you're talking about
They did only start coming fairly recently on newer 3905/ erevo style knuckles though, so maybe Popoxx didnt have any on his stock knuckles that are a bit older, but still 3905/ erevo style- I think that is where the confusion is coming from.
Funny thing is though, I just went through all the exploded views and the part listings on towerhobbies; absolutely zero info, pictures, or part #s for those metal caps. I've seen them with my own two eyes though- they fit in place of the blue rubber dust boot & retaining clip on the back of the pivot balls, yet I cant seem to fnid them anywhere
Best bet is it to find something similar that will fit, or make a metal plate to screw on the back like the ImpaktRc knuckles:
http://www.impaktrc.com/product_info...oducts_id=3641
Popoxx
Sapere aude
Popoxx's Avatar
08.09.2010, 04:23 PM
I wish I was at home to show you the instructions included with the 5334R axle carriers and which explains that these 2 rings have to be used only if you have the inner bearing of the 5334 model !! But I'm not at home
There are only 2 rings for 2 axle carriers because there is one inner bearing per carrier. That's why they are called "bearing adapters".
We're maybe talking about 2 different things Bondonutz...
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.09.2010, 04:39 PM
DING DING DING DING !
What I'm talking about has NOTHING to do w/the Friggin' bearing.
Popoxx
Sapere aude
Popoxx's Avatar
08.09.2010, 04:48 PM
If you're talking about the 2 rings you surrounded in you pic then you're talking about bearing... I hate this discussion
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.09.2010, 05:06 PM
NO ! there not for the God Damn BEARING ????
I hate this too and the language barrier.
Popoxx
Sapere aude
Popoxx's Avatar
08.09.2010, 05:14 PM
So let's stop here. I will post pic of what I want to show Friday when I'll be at home.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.13.2010, 04:41 PM
OK, Now that we have decent picture I can see where the miscommunication is.
I have circled the part I've ben talking about, this is what prevents the balls from popping out.
Kcaz25
Kcaz25's Avatar
08.13.2010, 10:51 PM
lol.
