redshift
RC-Monster Square Tube
redshift's Avatar
12.06.2009, 09:58 PM
"I thought the "Redshit" was funny too... Just cause I do the same thing when I am typing and do not even notice"
Yeah, except he meant to- don't think your cool old man, I haven't used a tenth of my wit here...
redshift
redshift's Avatar
12.06.2009, 10:11 PM
^ Just kidding, was about 90%.... shit knock-knock jokes 'bout max me out.....
redshift
redshift's Avatar
12.06.2009, 10:26 PM
Step 4: Dealing with Denial
You gots the wronk moter. Now cut your losses and get on TRX (if you haven't been booted?) and sell those fresh-outta-the-egg noobs that motor for $275. You can tell them it's a hybrid Kryptonite-Ion Drive and will go 120 mph on a watch battery!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.06.2009, 10:31 PM
Right here buddy.
redshift
redshift's Avatar
12.06.2009, 10:36 PM
I saw what you did in that MA thread on RCG, I can just imagine you on TRX....
In retrospect I felt kinda bad for RCG... Not JAMbag, but those wholesome types who might have never seen such graphic depictions
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.06.2009, 10:41 PM
You talking about the picture I posted of 2 dudes ?
Yeah, that was my better ideas.
Shock value is a scream aint it.
I was a member or TRX for a week or so be for a life time ban was issued, still can't remeber which offensive thing got me booted, there were so many ?
e-rev project
12.06.2009, 10:55 PM
the one i saw was damn funny though, i think it was your crowning achievement... and banning
redshift
redshift's Avatar
12.06.2009, 10:53 PM
Yeah, that compulsive lipo liar deserves it, I had the feeling you wanted to post something a bit less tame... but you showed restraint, which was commendable
I'm sure he was left with a bad taste in his mouth that day too, and night maybe?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.18.2009, 08:37 PM
Ok, Update. I ditched the other motor ands M.M. ESC in favor of this. Novak HV Pro 6.5
Looky Looky
It's geared for INSANE, have yet to test. It's ben Freakin Raining all DAY !
jpoprock
jpoprock's Avatar
12.18.2009, 10:17 PM
Nice! What is all that other electronic junk? A BEC? What else? Looks like a Nasa project!
Did u make that roll bar? How did u mount it to the chassis? What are those zipties holding?
My Stampy isn't too far off from yours really. You've got nicer electronics and a bit more bling. I'm always looking for tips to make it better!
Looks like yer chassis is nice and polished too. How do u do that? My chassis is in good shape, just not as shiney as it used to be, and a bit scuffed. Some gobbly gook and a polishing wheel on my dremel?
Love the Slayer front body mount. Looks like the ticket! But that roll bar is great!
I can't tell u how many times I've bent my rear shock tower forward and had it replaced from upside down forward moving crashes. I wish there were a better way to keep it from flexing in either direction, outside of not crashing!
Looks stellar Bro!
J
  Send a message via Yahoo to jpoprock Send a message via AIM to jpoprock
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.19.2009, 11:56 AM
Looks stellar Bro!
J
Thanks Jason .
Had to have the BEC due to rewireing ESC for a single 4s, had to pull the red wire from ESC's plug. BEC gives the RX juice.
Roll bar is a narrowed MGT roll bar, mounted via 4mm screws
1 zip tye, holdeing ESC's capacitor to roll bar
I never polished mine ? It's still looking purty good even after getting run over by a full sized ford van. Crushed it ! Drove over the front wheel and shock tower and banannaed the chassis. I just straightened everything. EVen the roll bar, broke the screws and bent the shit out of it but it straightened.
SLASH Body mounts
I had the same prob w/rear tower untill I ran longer screws through and put a nylon lock nut on it. No worrys. Even after getting run over it's still fine !
Let me know if you want a pic ?
jpoprock
jpoprock's Avatar
12.19.2009, 01:30 PM
Ok.. so the Capacitor comes WITH the Novak? What is it's purpose?
I gather that the Novak doesn't have a built in BEC then? And if it does... does a single 4S muck that up somehow? Or does it only support 2x2S lipos Parallel?
I'm JUST now learning about BEC's, etc... All my trucks have either been Nitro, or had a built in BEC in the ESC. So, "extra electronic stuff" wired up is new to me.
What kinda tires are those? They look cool. Are those 12mm rims?
Oh, and does that rollbar only work with certain bodies? Or can you raise and lower it somehow?
Where did you get that diamond plate? That is cool! Do you have to unbolt it completely to change the battery?
You can email me pix if'n you want to man.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.19.2009, 02:15 PM
Ok, The Novak HV's come with the capacitors.
Someone else could explain the reasoning better than myself as to why.
My understanding is it'lll help w/possible heat issues, how ???
Have to have the BEC because the ESC is wired for 2 2s in parrallel and I''ve rewired it per Novaks instructions to run a single 4s, so I've lost the Internal BEC from a 2s pack. I just pulled the red wire from the ESC plug.
No the roll bar is pretty much for this body only, I can cut the legs shorter for other applications easy enough.
Diamond plate , FleaBay and it was cheap.
I have a 3700mah 4s, so run time should be good and long. Yes, must remove 4 screws to change battery.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.19.2009, 02:44 PM
OK, was able to test today for a few minutes
Geared now at 58/12 and needs to go up again, top end was decent (about 40mph)and temps were great but it cogged very slightly at low throttle inputs. Might try a 40T spur and see what that does because I have lots of room to go up.
