Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
06.27.2008, 11:03 AM
Temperature Calculation - Any thought of adding Kelvin?
06.27.2008, 11:06 AM
Two Speed Gear Mesh Calculator - Might want to add a note that this is for Mod 1 gears
Thanks all
06.27.2008, 12:20 PM
Arct1k, are you trying to find work for me to do?
Fluid calc: Good idea. Didn't change it too much from the original aside from visuals. Might add that feature.
Temp Calc: I think C and F are good enough. Who (besides you apparently) uses Kelvin when measuring temps?
Two-speed mesh calc: Why does it matter what pitch it is? I know the code is technically using Mod1 to get the gear diameters, but the ratio is what matters. The only reason Mod1 is currently used is because I was going to add shaft-to-shaft distance, but decided not to, and didn't feel like changing the mesh code again.
brushlessboy16
brushlessboy16's Avatar
06.29.2008, 10:59 AM
Medusa motors run 60k max rpm not 40k.
:D
07.01.2008, 10:07 AM
Fluid calc: NP
Temp Calc: Well Kelvin did... and it is rather cool ;) Not seen too many people measure distance in rods either
Two-speed: Hmm yes - its all relative...
07.01.2008, 12:52 PM
:SIGH: I suppose I can add Kelvin.
Added the extra oil mixture validation.
Added the CRT diff ratio.
The fix for the erroneous 40k rpm warning for the Medusa motor was a little different. The 60k rpm limit was entered correctly for that motor, but my warning system was using the old drop-down list method, so it was actually giving you the rpm limit of a whole different motor. Fixed now.
brushlessboy16
07.01.2008, 01:17 PM
yay
07.01.2008, 01:30 PM
Disagree with the math - On the range condition that A or B equals the target - this is fine it should just be 100% / 0% mix...
I had included >= in the forumla
07.02.2008, 02:42 PM
Oh all right, I made the formula inclusive instead of exclusive. It would be pretty dumb to mix anything with say 50w oil to get 50w oil, but I suppose...
Also reworked the two-speed calc page to make it a little easier to use. Also added a couple things to the gear diameter calc.
kopfpilot
07.10.2008, 06:46 PM
Is it possible to add the E-Savage to the presets?
07.10.2008, 06:54 PM
Sure, just give me the tooth counts of all the tranny gears and the diff...
kopfpilot
07.11.2008, 02:45 AM
Thanks =)
The specs for the E-Savage:
Front/Rear Differential Gear Ratio: 38/13
Transmission Gear Ratio: 33/19
Spur Gear: 66T 32P (Stock)
Could you add the Ammo 36-56-2600 brushless motor aswell?
It has 2600KV, 55Amps current draw and a ressitance of 0.0084Ohm.
07.11.2008, 10:04 AM
I'll add those ratios, but I try to stick to motors that Mike sells, will sell, or used to sell.
Any other changes people want before I upload the updates?
skellyo
skellyo's Avatar
07.11.2008, 10:36 AM
Can you get it to make me a sandwich when I hit the calculate button? I'm kinda hungry.
brushlessboy16
07.11.2008, 10:31 AM
umm isnt the rpm limit of L motors 50k?
Currently Active Users Viewing This Thread: 23 (0 members and 23 guests)
