ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
01.13.2011, 02:34 PM
Although I have no experience with a Dubro Tap. I dont think you will have a problem tapping the Aluminum. Which type AL are you going to go with 60 series or 70? I just used a cheap Kobalt brand tap and die set. Bought from Lowes. I think it is the Lowes "Home Brand". Just take your time and make sure you get the tap started in the hole straight.
Thanks for posting in my thread. I was just reading through yours yesterday before you commented. I looks forward to seeing what you come up with as well...
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
01.13.2011, 02:53 PM
Al is very easy to thread. I do alot of mine with just a screwdrive style tap holder and a steady hand. M3 and m4 threads usually do not even require any cutting oil. Just go slow, and when you feel some resistance turn the tab backwards 1/8 of a turn or so.
Best method I found to getting holes tapped perfect was to chuck the tap into the drill press and just turn it by hand while advancing it with light pressure on the press handle.
ZippyBasher
01.13.2011, 08:28 PM
So I am sitting & looking at the Excess 1/4" 6061, I have here and I thinking I can make an easy extended Rustler Chassis. I already have the FLM "Extended chasssis" But it only pushes the wheelbase to 12.5" ( 1 inch extension) and that thing is still just a wheely king.
I have just enough to make a simple chassis that will stretch the WB of the Rustler to about 16 inches even. I am thinking about trying out a "Mini Baja" type vehicle. Instead of a body maybe make a roll cage out of some Nylon rods or something.
Anyone ever seen a Rustler with an extreme WB like that ? I would love to take a look...
Thanks, Sean.
D8T - MMM 1717 6s
What I have been working on...
ZippyBasher
What I have been working on... - 01.17.2011, 12:01 AM
Some goodies from Christmas and I am getting a power upgrade and a new Short course look.
I got a Mamba Monster, 2 x 3s 5000 40c Zippy for 6s and I swapped my Castle 1520 in there.
SC10 Body, FLM Rustler bumper, RPM Slash front Bumper with SC8 Front bumper mount, SC8 Rear bumper and SC8 rear mount.
Photobucket
Photobucket
Photobucket
Here you can see Where I flipped the FLM Rustler bumper around. Mounted the RPM Slash bumper to it. Then drilled holes through so I could mount it to the chassis. Then I hooked Up the SC8 front mounts to the shock tower, and drilled two holes through the RPM Slash bumper. This thing is Rock Solid.
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
D8T - MMM 1717 6s
Rear Mount
ZippyBasher
Rear Mount - 01.17.2011, 12:09 AM
So here is the SC8 bumper Mounted to the Hinge pin cap. and Drilled two holes in the tower added a spacer screw and done.
Photobucket
Photobucket
Photobucket
Photobucket
As you can see here and the Top shot above. The length on the Slash bumper and SC8 bumper works just right...
Photobucket
Photobucket
Photobucket
Towel holding the body up. I gotta redo the mounts... Should be simple, I use new square style Maxx body mounts, They are easy to mount and tough.
Photobucket
D8T - MMM 1717 6s
ZippyBasher
01.18.2011, 01:34 AM
Raced the Maxx against our Ofna buggies and I was keeping a 1/2 lap lead for a good 6 laps. Man this thing is handling SWEEEET!
I WILL Have videos. Our "Track" is just an Oval out in the riverbed. But it is so much fun!
I blew a rear shock on the SC8ight and I think I might buy some MBX6 shocks for all around rather than a rebuild.....
Maxx 1717 CD 14/50 Badlands 55mph...
LX1E 1512 2650 14/51 Stock tires 65mph...
LX Comp 1518 18/51 Proline Crimefighter. 62mph...
All 6s, Crazy Fun
Oh and bought all new bearings for all three of my rides for 48 shipped from avid RC
D8T - MMM 1717 6s
simplechamp
simplechamp's Avatar
01.18.2011, 01:48 AM
Have you ever used Avid bearings before? I am using them for my Jammin on-road, so wondering how they are. I got the dual-sealed (one metal shield, one red rubber seal) to try out.
ZippyBasher
01.18.2011, 02:20 AM
No, this would be my first purchase from them. But I have many good things about them. I was also going to go for the "Revolution" or something 1 rubber 1 metal side. But I opted for dual Rubber since I run 80% off road.
The Revo. should be optimal I would think for the On-road though. minimal dirt/dust
Have you looked into bodies yet>? I really like that CF build. Top notch.
D8T - MMM 1717 6s
simplechamp
01.18.2011, 03:45 AM
Been browsing for awhile, still need to save the cash up for one. I'm either going to get one of the Deltaplastik, or a pre-painted, pre-finished IGT1 body. I'm leaning towards the IGT1, the Deltaplastik bodies are awesome and tons to choose from, but $90 for a clear body might be more than I'm willing to pay.
Kcaz25
Kcaz25's Avatar
01.18.2011, 02:49 PM
Good stuff man. I really like the Avid bearings. I am using them in my Mutant Maxx in all the knuckles. Revolution on the inside and rubber on the outside. They are all smooth.
That Maxx does sound like a good runner. 6s woohoo! lol
ZippyBasher
01.25.2011, 04:50 PM
Well, I got the new bodies all painted and they are looking pretty killer... I got some shots but I am at work and I didnt load them to photobucket yet... I will post them up later along with some shots of the "Rustler"...
Well I made my new chassis for the Rustler. It was actually extremely easy. Only took about an hour and half to file, drill and countersink all the holes. Its not something crazy fancy, its actually more like a Low CG - Super Stretched Stampede. Only thing I need to MOD is how the Steering top plate connects. The plates sits about 1/4" too wide for my chassis. So I may just make a small Block to attach the chassis to the top plate behind the servo. Should be simple and actually will act as a battery stop for the front.
It is 1/4" 6061-T6511 ~3 wide (not at home, cant remember). Wheelbase is right around 16 inches, and is not too stupid looking considering the width ( I have the EXT FLM Arms). It should actually look pretty cool once I hook up some "Roll Bars" to get that Baja Look. This will be ran on the CC-1512 - 2650, Mamba Max and use either 3s or 4s Depending on where I will run it. Geared 18/56 I should be right around 50mph on 3s with my Masher 2k's and I also have some Badlands 30's (about same height at 5" ) I will most likely switch to when I get the Roll bar done. Now I should be able to mount the batteries far forward and blast on the throttle and not just wheelie all day. I would guess about 5-6 lbs when I am finished.
Also, I bought a complete rebuild kit for some old 8ight shocks I had. I will rebuild them and slap em on here as well, to get a nice plush ride, 15mm shocks on a "Rustler"... Should be sweet.
POST SCRIPT: Anyone know the best kind of material to make a ROLL Cage out of ? I was thinking 3/8" Nylon Rod. But I am not an expert on plastics and am unsure if there is a more suitable material?
Thanks - Sean
D8T - MMM 1717 6s
Some Pictures!
ZippyBasher
Some Pictures! - 01.27.2011, 01:15 AM
So here is where it starts. I have had the rustler for about 4 years and its time for a little change. It has all the hop ups I needed then and I will make it as bullet proof from here out as I can. I plan to make this a jumper, as it is very light and I will have some nice shocks on it. As you can see it is narrow but its pretty much the same width as my brother law's FLM stampede chassis.
Photobucket
Here you can see I have 32p gears. I think its a 56t Jato spur. FLM Tranny, And if you look up in the front, you can see the posts for the front top deck are just off too far by about 1/4"
Photobucket
Here is an easy fix I came up with. I will just drill two new holes in the top deck, and mount the posts 1/2" closer to the center and 1/4" back (I put the screw app. where I'll mount it). This will also be an nice battery stop when I as some sticky foam to it. I got a 20kg/cm servo. So it will be no problems steering this. I also will put on my 4mm turnbuckles I had for over a year sitting here and replace the 3mm crap...
Photobucket
Another shot of the Rear. I keep the bearing carriers plastic as a weak point. I plan on tapping the arms at the hinge pins and using set screws. I have some serious slop around the holes and I dont want to send them back to FLM yet. But I probably will later and get a new full set...I also have Ofna dog bones for shafts so no worry on twisting them...
Photobucket
Shot of the rear tower with an Ofna Raze wing mount.
Photobucket
The mounts that came with the FLM chassis really made this easy and solid.
Photobucket
Photobucket
D8T - MMM 1717 6s
A bit more...
ZippyBasher
A bit more... - 01.27.2011, 01:18 AM
And here is a shot of the wheelbase. It ended up at about 16.4 inches.
Photobucket
Photobucket
Photobucket
So I threw my old E-maxx body on for fun. I will probably bash it in half till I can come up with a roll cage, but a little shoe goo here and there I should get a dozen runs or so... Its got tape on the windows and rear from when it was muddy and I didnt want it in the car...
Photobucket
And lastly, I really like this tire combo. I think it would be perfect for a stampede 4x4... They are masher 2k's stretched onto proline 30 series rims which are like 2.8" mounted on the insisde bead like people do to the half ups. ( Inspiration ). Lo-Pro Mashers, it really gets rid of the side roll problem inherent to the 2k's because they are soooo soft.
Photobucket
D8T - MMM 1717 6s
ZippyBasher
02.09.2011, 08:25 PM
So I finished up the electrics on the Rustler. 1512 on 4s geared 18/56. FAST. But damn near uncontrollable. The masher 2k's get absolutley no traction whatsoever when Off-road (probably because the 1512 and 4s). I might as well have just run around on just rims. So I slapped on my pin tires (Hotbodies ST tires) for my Maxx . and it handled great around our river track... Even for 2WD I was getting some good laps in. Even the GF was having fun with it, while my niece loves watching. So I ordered some Komodo LP tires, Ofna MT3 rims I will dye black, Just need to build my 8ight shocks and fill them up and slap em on, also ordered my "Rollcage" material. I went with the GS Nylatron 3/8" and I bought some .060" lexan as well to form a Body over the cage. Should be slick when its all said and done.
The 8ight has turned SC8ight. Body is mounted and looks good. Just need to rebuild my shocks and we will be rolling this weekend. I replaced all the bearing as well. The CD bearing were SOO shot, they had like 2mm play each. Also, when I rebuilt the diffs,I used a Nova-RC cup for the CD. Rear is Losi HD cup and front just stock...
And the Maxx, I rebuilt the 4 RC8 shocks with 50wt oil. I added LST2 sway bars to the rear (and it came out Fing Sweet) Just need to figure out how I will do the front sways. I also replaced all the axle carriers with new Slayer Pro knuckles and fresh bearings. And I will rebuild the diffs, When I do the front and rear diffs they will be getting Nova-RC cups as well as new AVID bearings. They have a sale on the bay right now for $6.50 a cup. (CHEAPER THAN HD PLASTIC CUP).
Will get some Pictures when I find my camera. Kinda sucks I got so much stuff and I cant take any pics... All my rides are being re-done. Will post soon.
-Sean
D8T - MMM 1717 6s
Some new Pics and Vids
ZippyBasher
Some new Pics and Vids - 02.14.2011, 09:58 PM
Got some pics now that the "Raja" is done.
Photobucket
Here you can see the 1512 and if you look close you can see I had to add some maxx big bore springs inside the losi spring because I wasnt about to spend $30 on adjust collars and more springs... But they actually fit great in there and will work perfect
Photobucket
Photobucket
Everything sits nice and low but I still get some good ground clearance. Maybe 3" or so.
Photobucket
Overall...
Photobucket
Photobucket
Still waiting on the Nylatron, but I did get the Lexan sheet.
Photobucket
TURN YOUR SOUND DOWN. HIGH WINDS. That is grass roosts not dirt LOL
D8T - MMM 1717 6s
