Go Back   RC-Monster Forums > RC-Monster Area > Product Reviews
Thread Tools Rating: Thread Rating: 25 votes, 5.00 average. Display Modes
slimthelineman
slimthelineman's Avatar
12.05.2010, 11:43 AM
Just use a bunch of the deans bulb dischargers they are 30 amp loads with 10 #1157 automotive lightbulbs. Wire a bunch in series and watch her glow. Kinda old school use to use them for ni-cd's and ni-mh packs but good size load for not much cash and real simple.
padrino
hmmm...
12.05.2010, 02:51 PM
I'm apt to do it, I would love to see 75C from that pack over and over again. Parts ordered!
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
12.06.2010, 10:40 AM
1157 automotive light bulbs, 2 amp load for each light, that would be 487 light bulbs to get a 75C load on a 6500 mah lipo right? That would not only light up the room, it would heat it in winter also. What could be used for a LVC?
No brain, no headaches.
maneba
12.10.2010, 04:12 AM
Why to keep this post alive?
Maxxamps has no intention to respond to your request.
Their only goal is to keep the discussion alive to "talk about" their products.
It's a basic marketing rule.
BIG-block
12.10.2010, 04:10 PM
I don't know guys but the diesel glow plug seed to have been doing the job easily. It got stupid hot but if you do the test on concrete I don't see an issue. One of them (at least the one I used) managed to pull just a little over 15A so I am guessing that you wouldn't need too many to test a lipo properly. I called one wrecking yard and they said that they wanted $85 for one second hand glow plug like the one I used so that wouldn't be feasible. I also called a truck wrecking yard and asked if the had some cheap glow plugs. They said that there are engines out back that I can have the glow plugs from for $10 a piece but I had to remove them my self. Still I am not all that confident doing this nor do I want to destroy any of my batteries so maybe I should leave this kind of testing to those in the know.
padrino
hmmm...
12.06.2010, 11:48 AM
at 2A each it's half the bulbs, isn't it? In addition to that I was looking at how to wire something up and expect the 12 awg MA puts on this pack will have issues before it gets close to 75C, off hand I don't know what it should handle before it falls apart but I assume it will?
slimthelineman
12.06.2010, 12:27 PM
It would take around 250 to get your 75c load. I'm guessing around 50c will do the cells in. And yes it's bogus to think the deans and 12awg wire will take these loads. These numbers are fake no tests have actually been done by ma at these amperage loads. The componets will not hold. Wire conectors and the sort. So if someone wants a space heater to destroy an ma brick go for it but make sure to get it on video so someone can actually post some real info on testing these packs even if the manufacture won't do it to back their products.
Also deans or another company used to make a series lvc to use with their bulb discharger.
mistercrash
Guelph, Canada, eh!
12.06.2010, 12:58 PM
I used to have a Deans bulb discharger with the cut off they called the black box. I was going with the fact that it had 10 bulbs and was a 20 amp discharger so I assumed each bulb was pulling 2 amps. 1 amp per filament. So when I calculated how many bulbs, I forgot to divide by two 250 bulbs is right. The black box cut off that was used back in the day with the Deans discharger was for 4 and 6 cell nicads, I was still using it when the nimh came out. Oh geez I'm old, I got in this hobby when the red 1200 mah matched Sanyo nicads were the hot ticket
Hair dryers
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Hair dryers - 12.06.2010, 06:11 PM
Wouldn't it be easier to hook up a few hair dryers or hair curling irons that can draw like 1000 to 3000 watts each. I know you would have to do several cells at once to get enough voltage, but 250 bulbs sounds like too much work to get setup. Or maybe some other kind of heating coils that would easily draw enough amps to get 75C without having to build a small city of lights. Maybe some 12volt block heaters, or a 12volt motor with some kind of load in it. Maybe a compressor, or a generator. Then just apply a clamp on amp meter to measure the exact power draw.
SUPERMAXX YOUR LIFE.
Finnster
KillaHurtz
Finnster's Avatar
Its really unfortunate that these cells don't come in a smaller capacity that would be more feasible to stress. Tho I'm not shocked.
In all these shootouts (such as bigsquid), I don't understand why they don't use small cells, like 2200mah, and put them in a 1/8th and run them hard and make them work. Putting a 1/8th size batt in a 1/10 scale and doing light runs is a waste of time.
If the cell chemistry is all the same, the difference in the cell capacity variants can be largely ignored
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.06.2010, 07:36 PM
I have to do some digging but I may have a pretty good way of holding a large load on a battery. I have a 700 Watt DC-AC power inverter. It has a low voltage cut off at 10V but I'm not sure what the max input voltage is. It's designed to be hooked to a car battery so I know it will handle at least 14 but If it would handle 4s lipo I could hold about a 60 amp load on a pack. I could still run the pack through my Eagle tree for Data logging or even do a live view so I can monitor the voltage and cut it before going below 3v/cell. I know 60Amps isn't anywhere near the "rated" capabilities of these packs but it would be a continous load at more than twice the average current draw they would see in RC use
sikeston34m
sikeston34m's Avatar
12.06.2010, 08:03 PM
I've considered this before, since an AC inverter can really generate ALOT of DC load.
Problem is: The lower input limit is 10v, but the upper input limit is 15 volts.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.06.2010, 08:10 PM
Did some searching and I found that the input voltage was limited to 15V as well. It could still test a 3s pack down to 3.33V/ cell
josh9mille
josh9mille's Avatar
12.06.2010, 08:37 PM
How about a car hydrolic pump? Thos guys run upwards of 16 batteries sometimes. and they are wired in series and parallel. You can pick up a pump for fairly cheap and hook up a cylinder to it. figuring out how to put a load on it is another story though....
whitrzac
Can't catch this...
whitrzac's Avatar
12.06.2010, 09:16 PM
you can get old 100w+(no typo) resistors from surplus places on ebay for 10-20 each...
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
