brainanator
brainanator's Avatar
04.01.2011, 12:54 AM
dang! That center diff literally exploded....wow! lookin good though! can't wait to see it up and fully running.
Fun build
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Fun build - 04.01.2011, 02:56 AM
Yea this looks like a fun build project. It is fun to come up with new ideas and try things that others may have failed at, but in the end you learn more about R/C design and construction. It kind of lets you see exactly what some of the manufacturers have to go through in order to come up with a half descent vehicle. Trial & error is the best way to learn. I do like that piece of channel you came up with, and for free. Can't beat that with a stick.
Considering the sheer size of your build, the size of the 1717 motor and the added stress you are giong to put through this thing you really do have to elliminate your drive line weak points. Using plastic in any of your drive line IMO is just asking for trouble. If you want this thing to last for any length of time get your diffs all setup in alloy to avoid inevitable failures. If there is any way to use hardened steel gears I would do it. Alloy diff cups and cases will give you ultimate strength, reduce flexing, and help avoid disaster and more delays. Just my 2 cents. Nice project, keep up the great work, and thanks for sharing your experience with us.
SUPERMAXX YOUR LIFE.
Candyman2
Candyman2's Avatar
04.01.2011, 03:35 PM
If your putting a centre prop shaft in make sure you use something like 8mm/10mm tube to extend it. Dont be tempted to use bar as it will bend, has to be tube.
zueslilbuddy
zueslilbuddy's Avatar
04.01.2011, 04:17 PM
Thanks for the advice but I'll be using Hardened Steel rod.
Having it made up at the machine shop very soon.
It will not be welded, but will be like v8hatch's with the set screws to make it easier to change out the shaft ends if I happen to break a dogbone end or cdv end.
brian015
brian015's Avatar
04.01.2011, 07:35 PM
This makes no sense - a solid rod is stronger than a hollow tube of the same OD.
bigsteel
04.01.2011, 08:13 PM
I'm pretty sure tube is stronger in a driveshaft application,never seen a solid shaft on anything full size either.
Candyman2
Candyman2's Avatar
04.01.2011, 05:28 PM
fair enough but at that length i'd still go with tube, time will tell. :)
brian015
brian015's Avatar
04.01.2011, 10:11 PM
So you take a solid rod and drill a hole through the middle, making it hollow, and it's stronger?
Take note, that I say "of the same OD" - to make his driveshaft out of the cvd pieces fit into either a tube or solid shaft drilled out at the ends he must have a similar OD rod or tube.
A tube of the same weight as the rod (meaning it's made from the same amount of material as the rod) will undeniably be stronger. But that is not what is under discussion.
Candyman2
Candyman2's Avatar
04.02.2011, 04:05 AM
lol: do some research bud.
years ago they made propshafts on cars out of bar, they would twist unless they were REALLY thick and very heavy, a tube of the same diameter with a very thin wall (1mm) is just as strong and will resist and bending.
Yes, fact im afraid, it will resist the torque and not bend, strange but true, thats why all car props are made that way, makes them much much lighter than solid aswell.
brian015
brian015's Avatar
04.02.2011, 07:14 AM
OK: http://wiki.answers.com/Q/Which_is_s...low_steel_pipe
http://answers.yahoo.com/question/in...7125516AAcFkuI
http://www.off-roadweb.com/tech/1101...ube/index.html
Bottom line: what I stated in my previous posts is exactly right. Again I say that a tube made out of the same amount of material can be stronger, but it will have a larger OD - that is not what is under discussion here.
Candyman2
Candyman2's Avatar
04.02.2011, 07:31 AM
never mind,
sorry to clutter up your thread.
Good build, keep it up :)
brian015
brian015's Avatar
04.02.2011, 07:35 AM
THAT is right yes, its stronger as in , if you try to bend it, but NOT for torsional rigidity, i.e if you twist it as in a propshaft. A tube wont twist under a load where as a rod of the same diameter, like in this particular application, will. Im not a mechanical engineer, but it has to do with it having twice the surface area, inside and outside rather than a bar only having 1.
So please back that claim up with some evidence.
zueslilbuddy
04.02.2011, 08:17 AM
never mind,
Don't be sorry, disscussion is a good thing, its how we learn.
I have been using brian's and v8hatche's builds as guides and when I asked v8hatch what he used for his front shaft he said this.
Originally Posted by v8hatch View Post
It's solid 12mm rod, it's all i had. I took it to a guy i know that has a lathe and drilled into each end then drilled and tapped the side for the grub srcews.
So since this has been working for him I figured it would be a good way to go since like I said before.
It would be cheaper and easier in the long run to make the shaft like his.
I'f say the dog bone end happened to twist off the shaft, I could just loosen the set screws and change it.
Funny thing tho, show me a monster truck (rc) that runs dog bones, that has hollow dog bones?
The only hollow ones I've ever seen were slider shafts, and we all know how easy those twist (usually plastic).
I don't know, I'll go with what I've planed out and if by chance a solid hardened steel shaft breaks I'll try tubing
Candyman2
Candyman2's Avatar
04.02.2011, 08:20 AM
You'll be ok, that hardened shaft should resist a small bomb going off!
bigsteel
04.02.2011, 09:18 AM
Since yourgoing so over kill on the shaft anyways forget my post,you won't have enough power to twist that huge shaft,your weak point will be the smaller components anyway
