Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
mikey84
05.09.2011, 11:19 PM
ya $20 was a steal they wand 70 for one twice that size
http://cgi.ebay.com/7075-T6-Aluminum...ht_1343wt_1139
brian015
brian015's Avatar
05.10.2011, 06:47 AM
That's a larger sheet, so still a good price - they sold out of the one I bought.
el tomaso
05.10.2011, 07:20 PM
I really like your plan. And its never a bad thing having more 1717-powered custom RC trucks in this world
TG
brian015
brian015's Avatar
05.10.2011, 08:22 PM
TG
I agree! I put together the rear diff tonight with some of these parts (and some others):
So I can get it installed with the rear center cvd and see where the cd/motor mount need to go.
Bmr4life
05.13.2011, 04:04 PM
How are you cutting the aluminum?
mjderstine
mjderstine's Avatar
05.13.2011, 04:52 PM
why not some countersink bolts?
brian015
brian015's Avatar
05.13.2011, 06:08 PM
All by hand:
Even the long 24" cut:
McMaster-Carr did not have M4 flat head bolts long enough - I needed these to be 70mm.
Bmr4life
05.15.2011, 12:20 AM
Originally Posted by brian015 View Post
All by hand:
Wow, so you wrapped a hack saw blade with tape and went to town huh? How long did that take?
brian015
brian015's Avatar
05.15.2011, 07:17 AM
Actually, I was able to use the regular hacksaw with a 12" blade for about 9" in from either side. Then the frame of the saw got in the way of cutting further. It was only the center 6" or so that I needed the blade with the tape handle. It took a little time and patience, but with practice, I've found that I can cut very straight with a hacksaw - its long straight blade can serve as a guide once the cut is started.
mikey84
05.13.2011, 06:26 PM
takes alot of patience there
Jahay
05.15.2011, 06:12 AM
mate! you really do have patience to cut your own alloy... and so perfectly as well!!!
Nice job!!!
Bmr4life
05.15.2011, 10:26 AM
Well that's good to know.
brian015
brian015's Avatar
05.16.2011, 07:21 PM
Here's the motor mount I made out of 1/4" Al angle (1.5" x 2"):
I drilled the slots so that I could use the range of pinion gears I calculated I might need with the 50t and 54t spur.
brian015
brian015's Avatar
05.16.2011, 07:24 PM
And here is the installation of the CD and motor mount:
I'm using the Muggy CD mount with 1/4" spacers underneath for clearance with the 50t or 54t spur gear.
Bmr4life
05.23.2011, 08:38 AM
How did you make your slots in the L channel?
