josh9mille
josh9mille's Avatar
04.20.2011, 01:25 AM
flatheads dont get packed with dirt like all other screws. I hate digging dirt out of all my screws, thats what i use my smallest hex driver for. On the other hand i dont miss stabbing my hand with a flathead screwdriver when it slips.
Cody.McP
04.20.2011, 01:28 AM
Flat heads would actually be pretty decent if the slot was captured on both ends. Would never have to worry about stripping, thats for sure.
rawfuls
roofles.
rawfuls's Avatar
04.20.2011, 01:40 AM
Gotcha, makes sense.
What are these "square head screws"?
Square
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Square - 04.20.2011, 01:59 AM
Simple. Instead of using an allen type of slot in screw heads quality carpenters have been using square heads for many years now. I have never seen them used for anything other than carpentry, but they are a very solid choice for building. Much easier to deal with and give you a solid driving experience for locking in any project. Most cabinet makers use them for hidden attachments because they are easy to drive blind. The tool head slips in easily and dose not slip or strip.
SUPERMAXX YOUR LIFE.
04.20.2011, 06:10 AM
umm, they're square
Your the man harold.
JERRY2KONE
JERRY2KONE's Avatar
Your the man harold. - 04.20.2011, 06:21 AM
Funny. Your the man Harold. I should have thought of doing that when I posted. That should clear up any confusion for the square drive screw. What about showing the rest of them as well. Take us to school young man.
OK here is an allen head capscrew.
04.20.2011, 06:30 AM
google images, for all your giving rawfuls crap needs
bruce750i
bruce750i's Avatar
04.20.2011, 07:37 AM
Yeah, we can machine better screw heads now. R/c guys in the 1700's had no way to drive screws at 10,000 rpm, let alone file a five point hole in a screw head.
Also In a pinch Home Depot only offers m4's in Phillips or Flat head:)
BIG-block
04.20.2011, 10:33 AM
If I had a dollar for every time I stabbed my hands or fingers with a flat head screwdriver I would be a rich man. I hate the flat head screws. I like the flat head screwdrivers though. One of the most useful tools in the garage just useless as a screwdriver.
My favorite is hex screws. I refuse to own a RC that doesn't have hex hardware. My XTM Rail came with Philips hardware and that has all been changed now. All my ohter RCs have hex hardware as standard fittment.
Shimmy
04.20.2011, 11:32 AM
I too cringe when I have to use flatheads or even Phillips.
A big thing I like about allens is that no pressure is needed to use them.
Although a decent fitting flathead shouldn't need much either.
I get why Phillips might be better than flatheads in some areas but I hate them just as much, they look tacky, need more pressure, can be easy to strip and just a general PITA.
Square or Torx would be nicer still I think, should be even harder to strip (even with low quality tools).
I spose for flatheads and Phillips, a lot of people will most likely have 2 or 3 drivers, and it's possible to use these 3 for almost all screws.
Compare that to allens where there are a lot more needed, and that's only for one measuring system.
Generally speaking
JERRY2KONE
JERRY2KONE's Avatar
Generally speaking - 04.20.2011, 11:46 AM
generally speaking I have all Maxx type trucks in my collection, which use all 1.5mm, 2mm, 3mm & 4mm screws even with grub screws, and all of the hop-ups and mods I have done, so that being said I use four different sizes of allen tools and that is it. Sure I have a full set of metric, and sae racing allen tools, but rarely ever use most of them. Phillips strip much too easy and are just not worth the hassle. I would think that the Torx screw would be the best for our hobby, just because of the none issue with the strip factor. The only problem I have had with Torx is breaking the tools when using too much twisting force. I have yet to strip one. I noticed that even two or three of the deck screw suppliers are now using Torx heads for their higher grade screws.
rawfuls
roofles.
rawfuls's Avatar
04.20.2011, 11:37 AM
I think somebody needs to invent triangle screws..
Just to complete the cycle.
I've never seen those square screws...ever.
They look...odd..
JERRY2KONE
JERRY2KONE's Avatar
04.20.2011, 12:04 PM
They look...odd..
Go for it. Triagle would work well I think.
The sqaure screws have been around since at least the 60's or 70's and are mainly used by professional cabinet makers. I see them in other areas nowa days as well, but they are not very popular just because people don't appreciate that square look on their creations. Like I stated prior even cabinet makers use them mostly for hidden connections under countertops and in places not normally seen by most people.
rawfuls
roofles.
rawfuls's Avatar
04.20.2011, 12:24 PM
Honestly, I actually am starting to kinda like the look.
I'm just a bit odd..
I don't know, industrial aesthetics appeal to me..
Which is why I bought lots and lots and lots and lots of black allen cap head screws.
Use them on all my projects!
bparanoid
04.20.2011, 04:08 PM
Square head screws are commonly known as Robertson's named after the guy who invented them in 1909 http://www.robertsonscrew.com/ For some reason everyone knows Mr. Phillip but Mr. Robertson is the square head guy. They have been used in Canada for quite some time.
