cmac
cmac's Avatar
07.26.2011, 07:44 AM
ESC plate made. New a-arm just shipped. Now on to the next item on the list. What are my options as far as getting custom dog bones made? I know Mike can make them, but he is so busy, and I don't know how long it would be until he has a chance to get to them. Are there any other company's that make them? Also I need to know how to measure them. Do I measure to the very ends of the groves in the cups or do I want a little room?
07.26.2011, 01:23 PM
Pin to pin is usually the normal way of measuring, check if Kershawdesigns.com can help- Dan is usually good to deal with. You do want to leave about 1mm at either end of the dogbone/ pin to allow for chassis flex without the dogbones binding up or bending. Once the CD is mounted you can use calipers to check the distance between the drive cups + the depth of the slots for the dogbone pins.
cmac
cmac's Avatar
07.27.2011, 12:08 AM
Front drive shaft 83 mm (that is with the 1mm subtraction on each end), and the rear I will need a 131mm bone (minus 1 mm on each end). I found a 83mm Duratrax center dog bone, and a 131 Ofna center dog bone on Ebay both for under 20 dollars. They are on the way.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
07.27.2011, 09:08 AM
I'm not sure if that was luck or judgment, but those should work quite nicely
cmac
cmac's Avatar
07.27.2011, 09:16 AM
I assure you that it was all luck!!!!
cmac
cmac's Avatar
07.28.2011, 12:41 PM
I spoke to Dan at Kershaw Designs and he also has a set that will work so I bought them for only $23.00. I guess that they can be used for back-up.
cmac
cmac's Avatar
07.28.2011, 09:25 PM
Well, just got my replacement arm and it is perfect.I think I will try to redo my ESC plate. It is functional, but it's not my best work. I want it to be perfect so I will try again this weekend.
cmac
cmac's Avatar
07.30.2011, 04:41 PM
I received the dog bones, and the front shaft(83 mm) has a hair more than 2 mm of play. How much is reasonable?
WEB
07.30.2011, 05:32 PM
That should be fine,you can put a Oring in each drive cup to take up the play or a slice of fuel tube it works to and then you are good to go??
Kept the good work going it would be looking like a truck now???
cmac
cmac's Avatar
07.31.2011, 08:09 AM
Not really yet. I'm still waiting for my new sheet of aluminum so I can make the ESC mounting plate (second try). The first one came out functional, but not perfect. I will try again. Does anyone know what size nut go on the end of the UE 6mm CVD's? My set did not come with the nuts.
WEB
07.31.2011, 09:47 AM
Just use standard 6mm wheel nuts will fit the UE cvd"s,can you show us a pic off where you are up to,that would be great???
cmac
cmac's Avatar
07.31.2011, 02:57 PM
I'm planing on showing lots more pictures. I'm just waiting on more parts
cmac
cmac's Avatar
07.31.2011, 06:58 PM
I have fixed the slop in the front shaft with a piece of fuel tubing, and now have the perfect amount of play in the back shaft thanks to my father-in-law's bench grinder. Feels good to have a working drive-train!!!!!!!! As soon as I assemble the A-Arms and CVDs I will post pic's. Only problem I have right now is that I'm waiting on a set of hinge pins.
cmac
cmac's Avatar
08.02.2011, 07:05 AM
So what is everyone's opinion on Lunsford or UE"s Ti hinge pins?
08.02.2011, 09:00 AM
I tried the lunsford ones on my crt.5 and found that they bent much easier than steel - I was very unimpressed.
