Originally Posted by suicideneil
Cold solder joints where the bullet connectors ( motor > esc ) are attached to the wires; the solder melts inside the cup just fine, but it doesnt stick to the metal. If you tug the wire, it comes out with a cup-shaped plug of solder on the end and the inside of the cup is clean as a whistle inside ( like a cup of ice- warm the cup and the ice drops out in one solid lump ).
Otherwise I'm fresh out of ideas..
Ah ok thanks for clearing that up.
I assume you used batteries that worked perfectly fine when you tried this out? How many cells in total did you use on the MMM and the XL, and what kind of batteries (C rating, mah etc.)
Also, what servo did you use on the previous setup with the MMM? Did you have a BEC?
Did you test the ESC's with another motor by the way?
