E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.06.2011, 02:22 PM
Achieving those speeds in a 5+lb 4wd truck on 2s is impressive. I wouldn't want to be your lipos though, thats putting some serious draw on them
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.06.2011, 04:25 PM
Impressive it is. What is more impressive, is that Patrick himself is giving me advice on how to make it work on my cheap lipo's. Time to get a Hyperion 45C 5000mah pack, if I can find one in stock.
The C40-5L Hacker and Neu 1506 6800kv motors are easier on the batteries, compared to the B50S Hacker. Timing on the Hackers is set for 5 degrees and the Neu at 10 degrees. The current GenAce battery pack is only good up to 60% capacity. After that the CRT.5 is just slow.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Pdelcast
Pdelcast's Avatar
10.07.2011, 06:30 PM
Hey, one more thing...
ADD some capacitance to the battery side of the ESC. You are probably really stressing the capacitors. If they fail, the controller will go BOOM.
Patrick del Castillo
President, Principle Engineer
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.07.2011, 11:32 AM
I went ahead and played around with the torque settings. I ended up with 9, which gives me good results. I'll drop the pinion a bit and see if I can bash with this motor.
10.07.2011, 12:00 PM
In a way, it's kinda neat how the PCB trace in the lipo blew. Sort of like a protection fuse. I know you defeated it (similar to replacing an old-style house fuse with a penny), but less knowledgeable people probably wouldn't chance it, which is probably good to help protect them from being stupid.
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.07.2011, 12:29 PM
I agree Brian.
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.12.2011, 10:55 PM
Tonite I finally had a bit of time to myself to work on the ESC. I added three 35V 1000uF Rubycon caps to the ESC and like magic my issues went away. ESC is very responsive now and brakes are better.
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.14.2011, 01:42 PM
Ran it a bit today during my break. I still get only 2100mah use out of my pack before the ESC slows me down. Batteries were barely warm. ESC and motor were below 180F. Gearing was 46/18 and speeds seem to be in the mid 60's. The extra caps were nice and warm. I'll change the deans out for EC5 and start to datalog this setup.
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.17.2011, 06:22 PM
Here's the vid of the torque control activated. Smooth startups. Even using the same batteries that I had to add some copper too.
[YOUTUBE]4uZKCUJplus[/YOUTUBE]
ta_man
11.18.2011, 11:11 PM
What firmware version are you using?
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.28.2011, 01:02 PM
I'm using the latest firmware on both of mine.
Emaxx_Quebec
Emaxx_Quebec's Avatar
11.28.2011, 01:24 PM
That's where is your prob!
Go back to 1.24
anunaki
11.28.2011, 01:42 PM
Go back to 1.24
someone please confirm this is THE LATEST CASTLE FIRMWARE FOR THE MONSTER GLICH FREE OR NOT?whoever brought this up, castle helllllp!
Pdelcast
Pdelcast's Avatar
11.28.2011, 02:42 PM
The latest Castle firmware works just fine. The stutter problem snellemin was referring to was caused by the pack voltage dropping so low on startup that the processor on the ESC was resetting. As he said, adding additional capacitance to the input and using some torque control solved the voltage sag problem.
Thanx!
Patrick
anunaki
11.28.2011, 03:41 PM
Thanx!
Patrick
thanks for clearing that up sir.
