E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.24.2011, 10:33 AM
Originally Posted by fastbaja5b View Post
Buy a HPI Q-Base ESC
Personally I hate it, I wish I had the standard MMP wires not solder posts, if for whatever reason a solder joint fails and comes adrift, you have a far greater risk of dead shorting your battery (Or maybe I should learn to solder better)
HPI esc doesn't have solder posts for everything. It's also not the same as a Castle esc because you are limited to firmware that HPI approves. As far as soldering goes, if you have solder joints coming apart while running and nothing else is wrong then yes you need to learn to solder better. Only time I've had a problem like that was when the something else went wrong and burnt down the system, only happened once so far in 5 years
