RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
08.19.2014, 03:48 PM
Your fix should work well, Nick. Making a small flat on the cross pin where the setscrew engages it is a common fix for this issue as well(along with locktite on the setscrew of course).
08.19.2014, 04:08 PM
What MMike said, you can also use some heat shrink to hold the pin in as you did with the O ring. If there is a clearance issue, which there most likely is not. The flat on the pin and Loctite on the setscrew is the way to go.
nastety92
08.19.2014, 08:33 PM
Thanks for the replies guys. Im not sure what setscrew you are refering to? The pin holds the hub, the part the wheel screws onto, in place there is nothing else holding it onto the driveshaft.
Maybe I am missing something. My D8T has a different design than this one and I think that one has a setscrew in it.
Nick
Tamiya TRF801Xt-e
bdebde
That's All Folks!
bdebde's Avatar
08.19.2014, 11:30 PM
there should be a set screw in the center of the hub... same as the d8t.
nastety92
08.20.2014, 06:22 AM
I looked at this last night and from what I can see there is no set screw. I will pull out the owners manual/ instructions to see if Im missing those screws.
Thanks,
Nick
Tamiya TRF801Xt-e
bdebde
That's All Folks!
bdebde's Avatar
08.20.2014, 09:05 AM
Thanks,
Nick
ID:	10773   Click image for larger version
nastety92
08.20.2014, 09:06 AM
Thanks I just looked that up myself. I'll take another look when I get home today to see if the screw is in there or I didn't have it at all.
Thanks for the help,
Nick
Tamiya TRF801Xt-e
08.20.2014, 09:13 AM
Yep, looks like there should be a 4x4mm setscrew holding the pin...
nastety92
08.20.2014, 09:50 PM
Ok I found the set screws. I put them in first before the pin went into the shaft. I put them in correctly and it all seems to be tight.
Took it out for a test run in front of my house and drove it for 10-15 minutes before it cartwheeled down the street and landed on its wheels and drove back. Drove it a little more before noticing the front end is a little loose. It was a lot of fun driving it while it lasted. It's been over a year since I've driven a RC.
Im about to take it apart to see what is broken.
Thanks again for the help guys.
Tamiya TRF801Xt-e
nastety92
08.25.2014, 10:21 AM
Figured I would update this thread a little. I got the truggy back up and running. Luckily I just lost a screw and that's what was causing the loose suspension in the front.
Now I need to replace two of the metal collars that are on the bottom on the front arms that keep the front hubs in place. They keep on coming loose on me since I don't have the right parts now. I'll have to order those and go from there.
From pic 11 I'm missing BB5.
Nick
Tamiya TRF801Xt-e
nastety92
08.25.2014, 03:13 PM
So I'm looking for a replacement for this part. Wondering if anyone else has used a part like this on their 1/8th truggy or buggy builds?
http://www.ebay.com/itm/Tamiya-TRF-8...-/161313989250
Tamiya TAM9404944
Right now A-Main Hobbies shows 1pk still in stock. I'm going to try and order it but just wondering if there was another more readily available part out there.
Edit: I did order this part from A-Main now it does not come up on their website.
Thanks,
Nick
Tamiya TRF801Xt-e
ruudxd
08.26.2014, 08:42 AM
2 bucks, why don't you buy it on Ebay?
Or if you want to buy from a shop, losipartshouse, towerhobbies, rc-mart etc?
The new amain site sucks imo, I loved the old style.
nastety92
08.26.2014, 08:45 AM
I was just wondering if anyone knew of a replacement part that is not a Tamiya part. It seems like these parts are kind of hard to come by. I would love to be able to go into a hobby store and buy one that is used on a HPI, Traxxas, Mugen buggy/ truggy instead that is always available.
Nick
Tamiya TRF801Xt-e
nastety92
09.02.2014, 10:24 AM
Just a quick update. The kingpin bushings in the Hot Bodies D8T are the same size as the Tamiya truggy if anyone is looking for a replacement.
I will have this truggy back up and running by tomorrow.
Nick
Tamiya TRF801Xt-e
nastety92
10.21.2014, 03:49 PM
I'm looking for some front control arms for this truggy. Either the factory longer ones or the shorter upgraded ones. If anyone see's any for sale please let me know. I haven't found any online lately for sale that are in stock.
Thanks,
Nick
Tamiya TRF801Xt-e
