Deans plugs are great connectors, regardless of what you may have heard. I have used them on my Baja without issue - in fact years ago I had the HV boat esc on my Baja and ran it on 10s and 12s without any issues at all - a single deans plug soldered to the large double power leads of the ESC. A single poor solder joint will cause much more trouble than the Deans plug(rated at 50-75 amps continuous on paper I guess - every bit as good as the wire soldered to it as far as resistance and power handling capacity goes).
