coolhandcountry
coolhandcountry's Avatar
07.01.2006, 02:02 PM
Have you checked your servos? I have heard of them causing some glitching and such.
GeeReg
GeeReg's Avatar
07.01.2006, 02:16 PM
Yeah, it does it without the servo even plugged in.
RC10T2 - Novak SS5800 - 7-cell GP3700
HPI RS4 Nitro MT - Mamba Max 5700 - 2S 5500mah Lipo
MRC Thunder King - Mtroniks Truck ESC + Feigao 9L - 3S 6000mah Lipo
coolhandcountry
07.01.2006, 03:18 PM
Have your tried a different esc?
GeeReg
GeeReg's Avatar
07.01.2006, 05:11 PM
Well this is the only sensorless ESC I have and the system works fine in another truck so I don't know what to think. Unless there is something wrong with it that only affects it when it's in this particular truck, which I doubt.
Gustav
Gustav's Avatar
07.01.2006, 06:23 PM
TRy a reciever pack and an antenna tube and not running the antenna across the esc.
squeeforever
squeeforever's Avatar
07.01.2006, 09:08 PM
I would try something like removing all the electronic components (except the motor of course) while still hooked up and try to run it and then just add components to see which causes the problem.
GeeReg
GeeReg's Avatar
07.01.2006, 11:58 PM
I tried a receiver pack and tube with the antenna in different locations. Thanks though.
I'm going to try just a servo with a receiver pack with the esc unplugged and see what happens.
coolhandcountry
07.02.2006, 07:52 AM
Check around for any metal to metal rubbing as well. It can cause you headaches.
GeeReg
GeeReg's Avatar
07.02.2006, 11:16 AM
Yeah I checked all of the screws and other than that there isn't much metal-metal. I think I'm going to take the whole system and sit it on the ground and see if it does it, then put each one in until something happens, like squee said.
GeeReg
GeeReg's Avatar
Thumbs down 07.02.2006, 01:36 PM
Well I tried laying everything out next to the car and putting things in one by one. I can't get it to consistently not work so I don't know what's causing it. It has to be the controller in some form or another. The question is do I send it to Mtroniks or try (buy :mad: ) another controller first to see if it does it?
coolhandcountry
07.02.2006, 02:35 PM
did you try to reprogram it? I have seen the esc do some strange things cause it lost memory or something.
GeeReg
GeeReg's Avatar
07.02.2006, 02:47 PM
Yeah every time you plug it in you can choose to program the endpoints and I've done it over and over. Now it won't work in another truck either and it's acting strange like the throttle or brake wouldn't work, then they started working but reverse just barely moves at cog speed. I think it has to go back.
cart213
cart213's Avatar
07.03.2006, 10:34 AM
I've had that happen to my Mtroniks Truck before. After reprogramming the throttle and brake endpoints, it would always work again.
GeeReg
GeeReg's Avatar
07.03.2006, 02:07 PM
This hobby is supposed to be fun, right? I went to run my 1/8 buggy today and put in the new FM radio I was using on the MT. I get there and guess what...it starts glitching. Son of a ________!. I say to myself, "This can't be the problem. I tried the other PCM radio in it and it glitched before." So I get home, switch to the PCM radio in the MT and guess what, IT DOESN't GLITCH. Ugh, great so the problem is my brand new FM radio. I tried another receiver so it's not that. I think I'm going to try a different frequency set of crystals. If that doesn't fix it then I'm in trouble.
Cart: At least I know I'm not alone. It must be a software thing then.
GeeReg
GeeReg's Avatar
07.03.2006, 02:39 PM
Just got back from a top speed run. GPS says 46mph with 52/15 gearing and Dirt Hawgs. I also only got about 7 min of runtime. Does that sound right for a 6L? It is overgeared though so that might have something to do with it. Got some high temps also. It's about 90 out right now and the motor got to ~140, ESC ~ 145 and batteries ~160 in some places :026: . I think I'm gonna need fans. Again it could be because it was overgeared also.
*edit* Hmm. Out of curiosity I checked the voltage on the pack and it was at 10.25. Seems a bit high for a dead 8 cell pack. So I hook it up again and it's still fine. Does the Mtroniks have a thermal throttling where it will cut the voltage down or something and not just stop? Would it do it at only ~145 deg?
*edit 2* Or not....I just charged the pack and it took 3800 mah.
