zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.29.2006, 01:46 PM
Hey BrianG, what if you were to use a copper spacer in the esc instead of aluminum? Also, you could even cut out the bottom of the case and stick a nice heatsink right out the case and directly on the FETs. It would be a little risky though.
11.29.2006, 02:07 PM
A copper plate would conduct the heat better/faster, but really, Al works well enough once it is installed with less thermal resistance. The copper slab or cutting the case would work [b]better[/i], but I have had great results just doing what I did alone.
zeropointbug
Z-Pinch racer
11.29.2006, 02:41 PM
Well, you know what, i think i just might do this. Where do you start then disassembly then? Do you have a unsolder the motor tabs then?
You can just give a quick brief, i can take care of the rest...
BTW, don't you love how smooth the quark is?! It's so juicy.
coolhandcountry
coolhandcountry's Avatar
11.29.2006, 05:57 PM
I am currently running a 1512 2.5d neu on it. It is currently run with 4s lipo.
Yes I have trid 6s limn on it. It had a bad start up. After I got it going it was
ok. It was like had to warm esc up or wear batts down a little. When I say
start up. I mean like first hook batteris up and try to go. Not stop and go.
I tried 6s with a 1930 10t and it poof fried esc and motor. I have ran a 9xl on
it as well. I tried a xl 1200 basic. I have tried a 12xl as well. All the motors had
same issue with 6s. I went back to 4s and have had no issues what so ever.
I do get about 45 to 60 mins of run time on 8000 mah maxxamps pack. :D
Peace!
Country
Help support the
Rc-Monster
Buy here
neweuser
neweuser's Avatar
11.29.2006, 06:53 PM
Hey, that is pretty good run times CHC. I'm wondering what run times I'll be getting with my Neu 1515 1/y?
zeropointbug
Z-Pinch racer
11.29.2006, 07:00 PM
How i want a Neu motor... next year i'll get one, hopefully i'll have ran my 7XL before then. It's pretty snowy here now so, i'll see if i can seal up all the electronics and put my ProLine paddles on. ;)
Ya, that is very good runtime.
11.29.2006, 07:09 PM
CHC's motor is only 2000kv for about an L size motor, which is not a very "hot" motor. The 1515 1y is a larger can and higher kv (2200), so I'd say between 25 and 35 minutes depending on driving style, weight, etc.
zeropointbug
Z-Pinch racer
11.29.2006, 07:22 PM
Can you guys give an estimate what my runtime will be with the C-7XL, with the Quark125B and A123 pack of 5s2p of 16.5volts and 4.6Ah. It's a sort of buggy-truggy ;) ... it's high of the ground, but has 1/8 buggy tires (Badlands). The weight fully loaded will be around 7.5lbs.
Oh, and thats geared to go about 50mph
Any guesses? I am thinking around 15 -20max minutes?
jhautz
jhautz's Avatar
11.29.2006, 10:20 PM
The 1512 is definitly a bigger motor than the L can motrs. Much more powerfull also.
to make it...
or break it...
Silent...But Deadly
zeropointbug
Z-Pinch racer
11.29.2006, 10:30 PM
So, what do mean by that jhautz?
jhautz
jhautz's Avatar
11.29.2006, 10:40 PM
Just wanted to point out that the 1512 is a larger motor than the L can Feigaos is all.
Bigger diameter and it puts out more power than a Feiago L ever would.
to make it...
or break it...
Silent...But Deadly
Cartwheels
12.01.2006, 02:08 AM
You should really use the Arctic Alumina from Arctic Silver to bond the aluminum slab to the FETs. "Arctic Alumina Adhesive is a pure electrical
insulator, neither electrically conductive nor capacitive." here is a link http://www.arcticsilver.com/arctic_a...l_adhesive.htm . When I did mine I could not find it locally anywhere so I had to order it online. PC shops online are the best place to get this stuff. It is good stuff, but it's a perment bond!
I only bonded the outside FETs to the slab and case and did nothing on the aluminum slab that is sandwiched between the boards.
Your pretty brave doing this on a brand new controller! :027: but it does make a difference especially for bigger vehicles. It seems to cool quicker and overall more efficiently.
zeropointbug
Z-Pinch racer
12.01.2006, 02:25 AM
Hey, just to add, it appears once i took a closer look, that the slab attached to the case is only touching on the edges, it's not even touching in the middle...
Yes i was planning on using Alumina.
Do you think this mod is necessary for a 1/8 emaxx buggy? It will weight in at about 7.5 lbs. What do you think?
andywpj
12.01.2006, 03:35 AM
hello zerpointbug,
may i ask you, are you try setup your esc the Drag Brake function yet?
it's at menu Table 3.2-3 and Table 3.3-2 , would you feel free to test it
and try power off then power on, the function will off , if you set ON before.
i have 5 esc 2 new(3color wire), 3 old(white color wire), 2new esc can't store memory (just Drag Brake) , 3 old esc is normal.
i want compare your esc with me.
Thank you..
neweuser
neweuser's Avatar
12.01.2006, 10:30 AM
Originally Posted by andywpj
hello zerpointbug,
Thank you..
How did you get 5 of them! WOW! Do you live in Thailand by any chance? LOL
