glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.08.2007, 02:49 AM
Longer video will be live in a few minutes. It's almost 5 minutes long... 12MB.
The raw footage was only 7 minutes... it was kinda cold so I didn't waste any time, LOL
No damage to the truck but I did lose a body clip and a nut on a steering arm. I'll take that...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
glassdoctor
TEAM FUSION
02.08.2007, 02:56 AM
http://www.youtube.com/watch?v=Zbu5koAjscc
There.... that's all I got for now. But I hope to get more and better video soon.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
glassdoctor
TEAM FUSION
02.08.2007, 12:18 PM
Couple off body pics of the truggy without the rx..
ID:	2385   Click image for larger version
ID:	2386   Click image for larger version
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Procharged5.0
Procharged5.0's Avatar
02.08.2007, 12:32 PM
Great to see the pics GD!
glassdoctor
TEAM FUSION
02.08.2007, 12:45 PM
Oh... check out the monster fan over the motor/esc. That's why I stuck the esc there, so I could get two birds with one stone. The fan moves a lot of air. I ran this setup for over 30 minutes nonstop at the track in 90* heat and both motor/esc stayed around 150-160ish the whole time. It actually was a few degrees cooler right at the end than it was at one point earlier in the run.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Procharged5.0
02.08.2007, 12:50 PM
GD,
What settings did you use on the Mamba with the NEU???
glassdoctor
TEAM FUSION
02.08.2007, 02:08 PM
I have the MM all wrapped up (waterproofed) right now...
I don't remember the settings for sure... I'll post them when I get a chance to hook it up.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Procharged5.0
02.08.2007, 02:19 PM
I'd appreciate that. I might have you email them to me if you don't mind.....
wallot
wallot's Avatar
02.08.2007, 02:36 PM
Have to put everything together but the powerplant is mounted
http://www.radeks.net/?p=41&lang_view=en
Neu 1512/2.5D with Quark 125B
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
Serum
Serum's Avatar
02.08.2007, 02:42 PM
Wallot; those batteries won't give your setup the power it needs. Please clean up the wiring!! if anything gets stuck in the gears, you'll rip wires!
the top heatsink on the quark isn't really needed, the fetts are sitting on the bottom, so that's where it's needed.
You got a nice setup on your truck!! Nice...
glassdoctor
TEAM FUSION
02.08.2007, 03:01 PM
If you watch a few seconds into the video you will notice it cogging... did it several times.
But the settings on the MM:
brake:30%
drag:20%
Punch: 50%
Start: medium
Timing: low
cutoff: 12v
Nothing I have tried has fixed the cogging.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Dafni
Dafni's Avatar
02.08.2007, 06:50 PM
Nice conversion, Glassdoc! I like it.
I hope a MM software update will remove your cogging soon.
Procharged5.0
02.08.2007, 07:01 PM
Anyone heard when the when the update is due?
wallot
wallot's Avatar
02.08.2007, 07:02 PM
the top heatsink is needed as it holds the bottom ones tight to the quark. i might replace the heatsink just with 2 metal bars but it was so cheap i just got 4 heatsinks
i put the original gear cover on (after i have taken the pictures) so nothing can get there (actually added 2 new pictures of fully assembled maxx)
Batteries are temporary and they were ok with titans :) . I am waiting for battery bars so i can make 8cell packs from existing Sanyo packs i have been using and still deciding about better quality batteries to make new 8cell packs. Its winter anyway so plenty of time till I run maxx everyday, so I will spend a month or two with Sanyo 8packs for those few weekends
Radek
*EX-10 Eurus*
AAngel
02.09.2007, 04:35 AM
Man, just what I was afraid of...there is no end to it. LOL
Nice stuff, do you actually have the time to enjoy all of it?
