glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.13.2007, 09:25 PM
We have found that hardwiring helps a lot. Basicly the 4mm conns are crap. I have not tried the 5mm or 6mm beefy connectors but my guess is they would also be much better than the stockers. I just hardwired finally.... it's a no-cost mod. :)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
MM5700 glitching
Larain60
MM5700 glitching - 04.16.2007, 10:53 PM
Just to follow up I hardwired by mm5700 and the glitching was eliminated in the entirety.
Thanks.
glassdoctor
TEAM FUSION
04.17.2007, 06:07 AM
Nice!...
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Procharged5.0
Procharged5.0's Avatar
04.17.2007, 10:17 AM
Good to know! I have 6mm connectors and 12g wire but have yet to assemble & test it. When I do I'll give you guys an update.
AAngel
04.17.2007, 10:27 AM
The hard wiring does help. I temporarily went back to 6mm connectors, while I'm trying to figure things out with my setup, but when I settle on a motor/esc combo, I'm going to go back to hard wiring.
The 6mm connectors are nice, but they are still connectors. Some are tighter than others. Connectors are also prone to developing some sort of coating on them that over time adds resistance to the system. I'm going back to hard wiring because it simply takes one more variable out of the system and is just one less thing to worry about.
Procharged5.0
04.17.2007, 10:43 AM
There is a chemical the ensure ultra low resistance. It's used in hi-end audio to maintain "state-of-the-mind" performance.
I think the chemical is called "TWEAK".
I'd have to search for it. It might be worth trying since its intent is to eliminate voltage drops due to corrosion and not-quite-perfectly-tight" connections.
AAngel
04.17.2007, 10:51 AM
I do have this "grease" although it appears to be more of a gel, that is supposed to promote conductivity and prevent corrosion, but I'd rather just not have to worry about it. Hard soldering does't take long anyway. The only real draw back is that my spare setup will now have to consist of a motor and esc as one unit for quick swaps at the track. The spare is just going to have to wait.
Procharged5.0
04.17.2007, 11:00 AM
TWEAK is a clean clear liquid. Looks like superglue actually.
I also have a copper anti-corrosion paste for electrical connections and use in on my car (full size). I'm not sure if it's characteristics would be ideal for hi-amp brushless systems or not. I'll have to look into that.
riverat1540
riverat1540's Avatar
04.18.2007, 06:33 PM
Ok here is my problem. when i do speed runs my car glitches its like everything shuts down and kicks back on real fast its like losing signal and gaining it right away. i have my motor connected with 6mm bullet connecters and the motor is a feigeo 380 6l and im running a max amps 8000hv 3s lipo but it doesnt matter what battery or radio i use it always does it. i was thinking it may be because of the aluminum idler running against the steel top shaft. now im seeing this is common so how can i fix it?
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
Procharged5.0
04.18.2007, 06:40 PM
Try cleaning and reassembling the 6mm connectors. Make sure the connection is very secure!
Serum said his loosened up with use which makes brushless systems go absolutely nuts!
AAngel
04.18.2007, 07:00 PM
try running an external bec. I was having this problem with the MM too, until I went with the external bec. I don't have any technical details to refer too, but I suspect that the internal bec on the MM isn't the greatest. I believe that what you perceive the be glitching is the internal bec cutting current to the radio for a split second, the rest of the non response time is due to the radio rebooting. Try the external bec. The one that Mike sells is nice, but if you are on a budget, there are a bunch of linear becs that can be had for $10-$15.
riverat1540
04.18.2007, 07:06 PM
ok ill clean them would it be ok to use electric grease also to help connection i know it works great for towing trailer plugs
Procharged5.0
04.18.2007, 07:09 PM
I've never tried it on brushless connections and I'd be hesitant to do so.
Try electronic connection cleaner (similar to tuner cleaner) and wiping with a cotton cloth. available at Radio Shack or a quality electronic parts supplier (McMaster also sells it).
04.18.2007, 07:43 PM
A little more info on the MM quirks. I was reading through all the settings on the Castle Link and the "Start Power" description really interested me. It tells you to increase it for applications like crawling or if you experience stuttering at a standstill. Has anyone tried maxing this setting out? Although, I still think increasing the throttle limiting would help a lot.
AAngel
04.18.2007, 08:36 PM
Brain, it's funny that you should mention that. I emailed Castle and tried to get help with the problems I was having with my MM cogging in my Muggy. They told me to reduce start power to its minimum to reduce the current draw of the motor. That didn't make sense to me, because I figured that if the motor needs the current, it just plain needs the current. I tried it anyway, and things got worse. I turned it back up to the highest setting and things got better. Increasing the punch control also helped, but made it impossible to jump the truck.
