11.09.2008, 05:06 PM
Slipper adjustment is such a fine art...
... I said screw it, locked the slipper up solid (after my 3905 upgrade broke) and built a 6" long wheelie bar to keep the truck on all fours...
Does handle beautifully that truck, I need to get some of those tyres one day.
TruckBasher
TruckBasher's Avatar
11.09.2008, 08:17 PM
I still love watching your MAXX still looks great...Your modification was the reason I went for a slipper setup but I couldn't fabricate it so I just bought Mike's slipperential
E-Slayer direct drive to diff
Gee
A Horse's Ass
Gee's Avatar
11.09.2008, 10:00 PM
That is nice! I noticed the bullet connectors soldered onto the batteries themselves. Looks like a good idea.
BlackedOutREVO
11.10.2008, 12:48 AM
Originally Posted by plettenbergs View Post
nice truck candyman.that is my kind of ride.i like UE also!!
http://s302.photobucket.com/albums/n...=EMaxximum.flv
Sending PM!
TDC57
TDC57's Avatar
11.10.2008, 02:25 AM
WOW....
Those are TWO of the sweetest builds I've seen a long time.. Great JOB.. So when is the video coming out???
Nothing!.. Hahahahaaa..
Candyman2
Candyman2's Avatar
11.16.2008, 06:53 AM
Managed to squeeze the servo under the prop shaft and turn the linkage upsidown, much neater now.
11.16.2008, 10:51 AM
I can't believe it, really, it boggles the mind. Maxx bling already has a 50 page spread in history, and now, my god, it is even better! That servo mod is sick! I mean twisted! I should expect no less from your work, but wow!
BADASS CANDYMAN!
11.16.2008, 11:07 AM
Very nice. That servo layout is very clean. I love it!
Candyman2
Candyman2's Avatar
12.13.2008, 10:11 AM
I've never liked the 1 cell ontop of the 8 so I made a new chassis plate so I can lay 9 flat on each side.
12.13.2008, 12:06 PM
VERY nice but why you're still running NIMH is beyond me.
Mike_D
Mike_D's Avatar
12.13.2008, 02:18 PM
Your work is incredible as always but yeah that beast has to weigh a ton!!!
HB Ve8 x 2
Candyman2
Candyman2's Avatar
12.14.2008, 01:54 PM
lol, i like nimh, picked up a set of 3 nearly new packs GP4300's the other day, 18 cells in total for £30, you cant beat it!
weight is just under 5kg ready to run.
12.14.2008, 05:16 PM
That is a bargain I must admit- everyone is switching to lipo so they're selling their nimhs for cheap!
I must say though, that new chassis plate turned out alot nicer than my effort- ever concidered using the extensions on your truck to give it a longer wheel base (extended rear skid and extended rear-upper plate). Would mean a new rear dogbone from Mike or RcAlloys, but it might help tame wheelies and spare the slipper a little (from not having to loosen it as much as you do currently). Just a thought (I have a spare rear-upper plate I dont need if it helps sway your decision)....
Candyman2
Candyman2's Avatar
04.09.2009, 02:37 PM
me again! Done a job i've been meaning to do for a while, so this is the center of my truck
I have to use a 12 pinion on a 56 spur, even this is a little high with 18 cells now rather than 16. I cant go any lower on the pinion as it rips the teeth off the spur, plus the clutch has been getting anoying, it seems to be affected by temperature, some days it slips some its too tight and flips the truck, so really I want to go to a diff with a thick fluid, like 30k weight or something. Problem is on an 1/8th diff you have limited spur gear choice.
On the left is a 60T (i have a 56 aswell) mod one ofna gear from a 2 speed setup, on the right a gear that fits the 1/8th diff.
so i made this :)
it sits inside the gear perfect to keep it central
inside
bolted to the diff case for an airtight fit, I couldnt countersink the screws as its a bit thin.
just had to drill 4 holes in the spur to allow for the screw heads
squeeforever
squeeforever's Avatar
04.09.2009, 02:53 PM
Nice work! But why not just get the Ofna diff that uses those spurs?
