DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Thumbs down 04.11.2008, 12:56 AM
Why Can't They Give Us A ETA Or Price? Anything?
fromdaboz707
04.11.2008, 01:31 AM
I wish they would because i am on a small budget and i need to know when to buy my parts.
tha5150
tha5150's Avatar
04.09.2008, 04:16 PM
hey paralyzed, how fast is your 6.5 novak emaxx?? you happy with it? whats the setup? i am almost done with waiting for this MMM to come out and i blew my titans lastnight.
04.09.2008, 05:11 PM
8XL ok but you may wish to consider an align 600xl which is a bit more but I believe better quality and would take more V's to match the MMM.
PS and as this is the RCM site try mike at RCM however there are lots of people here with experience to guide you.
tha5150
tha5150's Avatar
04.09.2008, 05:21 PM
i have never heard of that. then again, i have 20 post, you have 1000... so i think you know a bit more than me..
fromdaboz707
04.09.2008, 05:24 PM
i have 1 post
DrKnow65
DrKnow65's Avatar
04.10.2008, 09:35 AM
Nice lincpimp :)
Hey joeling, how many mah and c-rating were the lipos that got hot with the 8xl?
joeling
joeling's Avatar
04.10.2008, 10:48 AM
Hi Doc,
Originally Posted by DrKnow65 View Post
Nice lincpimp :)
I'm using a 2S & 3S 4000mah Maxamps lipo (20C) in series for 5S. With a 8XL, I think I'm seeing 89A bursts under hard acceleration. Battery temps after 15 - 20 minutes was around 45 deg C + to nearly 50 deg C. These data has to be read in conjunction with ambient temperatures of around 33 to 35 deg C.
Maxmaps are relatively small & they fit into the buggy.
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
DrKnow65
DrKnow65's Avatar
04.10.2008, 11:11 AM
thanks joeling, I was curious as I'm going to build a hyper7 with 6S the MMM and a 9xl, so about the same amp draw. I have had some issues with my max amps lipos and will go with a better brand for my next ride, I think their 20C rating is a little inflated next to how they react to a heavy load. I think I'll either go with a 5000mah/20C or a 4000mah/25C setup, hopefully the increase in voltage will offset the amp needs.
fromdaboz707
04.10.2008, 06:26 PM
thanks for the info
Revracer
Revracer's Avatar
04.10.2008, 10:36 PM
so does anyone know when this thign will really be out? i got a brushless revo sitting here waiting for a good esc. im about to just get a mamba max since i am only running 3s... but it is on a 6pole...
kingiggy262
BL-Revo
04.11.2008, 01:02 AM
Just to let you know the MM and the MMM will be using the same firmware v1.17 so if you are only using 3s and don't need to pull 110+ amps then the MM will work just as well on your 6 pole motor as the MMM because the firmware is not different.
blueb8llz
04.11.2008, 02:11 AM
im going to run on only 4s with a 7xl, but im still choosing the mmm because if i was to get the mm, i will still need the fan and the cc bec which will add up to just about 30-50 bux cheaper than a mmm. and with the mm i will sorta have to worry about heat issues esp. when summer comes around whereas with the mmm for 50bux more, i wont have to worry bout a thing. and if i ever do decide to run on 6s, i will have the option there for me.
i dunno ...this is just me i think its worth the wait. ive been wanting to go bl on my 3905 since i got the truck which is only like 2 months ago, and i almost just went with the mm, but now that the mmm is sooo close, imma waitin.
DRIFT_BUGGY
04.10.2008, 10:45 PM
My project has been put off until the MMM is out
fromdaboz707
04.10.2008, 11:37 PM
i saw that on the r-monster stor they have a esc that can handle a 10 cell lipo nd 32 cell ni-mh but it is 450
