Hardstyle
Hardstyle's Avatar
05.11.2009, 06:55 PM
Must be some sort of country access limit in that site.
OK, thanks! The plate sit just fine in there, flexible stuff. Good thing though that it holds the diff much sturdier in place now.
And another prob is the front diff retainer. But it was easy fix, just worked a bit and fit there nicely.
My friend runned through one pack today with the new diffs and they work flawless. Noticed that it losed some speed, but that was expected. Have to put couple more teeths to the pinion now, systems are running too cold
Hardstyle
Hardstyle's Avatar
05.14.2009, 05:49 PM
Heehee, I have had awesome time with my g2r. Drove it like a maniac. Too bad my bowties haven't had that much fun, almost slicks now had to switch to hpi fatlines..
Gotta say, the diffs really are bulletproof works like charm! Now I really can give it WOT without fearing that the diffs will blow up.
Now that I have saw the cars limits, the suspension setup is far too soft it will bottom very easily. What spring rates would you guys suggest and what oils to use in the shocks? There's now green at front and pink at rear. Pre load is fully adjusted
Hardstyle
Hardstyle's Avatar
06.12.2009, 06:38 AM
Any suggestion for the spring setup? Maybe black for front and pink to the rear? Just checked I have Tan at the rear not pink like I said on the upper post..
It bottoms really easily now. Drive over a small bumb the front hits to the ground :P I think the extra weight on the batterys are the main reason why its bottoming. Maybe with lipos I wouldn't have that problem.
But yeah, throw me some ideas about the shock setup.
feistyacorn
feistyacorn's Avatar
07.01.2009, 12:05 PM
Hi Hardstyle. I am not so sure on suspension setup yet. I havent had alot of run time on my truck yet. The dang thing keeps breaking. I was looking at buying the v3 diffs today to replace the broken stock ones. What gearing are you running? What batteries?
Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
07.02.2009, 07:18 PM
Black springs in front and pink in rear would work. Take into account the weight balance of your truck, if it happens to be almost evenly balanced front to rear, then possibly black in front and silver in the rear. If it's rear heavy like the nitro revos then black/pink would be a better choice.
The timmy - Revo 3.3 MM 9XL 4s , Rustler MM 4600 3s
The ferty - Dual velineon Revo 3s, Rustler velineon 3s
Hardstyle
Hardstyle's Avatar
07.17.2009, 06:12 AM
Yau. Gearing is now 20/51 (for speed runs). Haven't drived for long time now, but have to see if next fall if I got time for my rc stuff.
Get the V3's, i know they r pricey but theyr worth it.. havent got any issues in my diffs since I got them. Look used one, might save couple bucks..
Hey thats precisely what I bought, haven't installed them yet.
