10.12.2008, 12:47 PM
I hope the MMM combo comes in soon. Really looking forward to some vids!
10.12.2008, 04:13 PM
Last Muggy conversion I saw had the Rx placed on the little deck by the front or rear shocktowers, such is the size of the Muggy and smallness of the Rx he used.
Unsullied_Spy
Unsullied_Spy's Avatar
10.14.2008, 12:13 AM
That's where I put mine. Spektrum SR3000 with some double sided 3m sticky pad and it fit really well.
roweder
I got my MMM Combo!
roweder's Avatar
10.15.2008, 04:38 PM
How about a layout pic? I kept the stock radio box, and modded it a bit...
I thought about putting it on one of those plates, but the mmm is going to be either behind the motor or the battery tray, and idk if it's wire could go all the way to the reciever
  Send a message via AIM to roweder
10.15.2008, 05:49 PM
Rear plate should be fine, then its just the servo wires that might not be long enough to reach the Rx; god bless servo wire extensions
brushlessboy16
brushlessboy16's Avatar
10.15.2008, 06:26 PM
why only front brakes?
cembom
10.15.2008, 07:41 PM
For front flips....
roweder
I got my MMM Combo!
roweder's Avatar
10.15.2008, 09:33 PM
because I like mechanical breaks better cuz they keep the bl stuff cooler, and the only way to use mechanical brakes and put the battery twords the front that i could find is what i did
brushlessboy16
10.15.2008, 09:41 PM
I understand why to use mechanical brakes- but why JUST the front?
10.15.2008, 11:12 PM
That's some SERIOUS toe-in on that rear wheel!
drkdgglr
10.16.2008, 03:16 AM
I received my muggy yesterday. I placed the brake servo in the same place, but the other whay around, with the horn facing the inside of the truck. This way I can use both brakes without further adjustments. I only had to use the outer hole on the servo arm.
roweder
I got my MMM Combo!
roweder's Avatar
10.16.2008, 03:53 PM
i couldn't find a servo position that could pull on the front and rear breaks
roweder
I got my MMM Combo!
roweder's Avatar
10.16.2008, 03:55 PM
do you have a picture of that? I'm not sure I understand how you set yours up?
drkdgglr
10.16.2008, 03:59 PM
sorry no pic yet. I have the servo mounted in the opposite direction of yours...rotated 180deg.
roweder
I got my MMM Combo!
roweder's Avatar
10.17.2008, 08:34 PM
How does that allow you to use front and rear brakes? I really want to find out how you did that, please tell me.
