joeling
joeling's Avatar
06.05.2009, 11:49 AM
Here's mine :
Medusa 60mm 2000kv, 14t pinon, 4S 6000mah lipo.
Gonna try to run her tomorrow.
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
Cain
06.05.2009, 01:03 PM
well I have had my first issue with the speed passion ESC. Didn't even get to run it. :flaming:
Had everything all set, ready to go, and when I went to turn it on, the switch was VERY loose, just tapping it would kick it on from on to off. Tried it a few times, and off it comes. Great... And since the switch is integrated (3 wires), I am not sure what wire can I splice together like you do on other cars to get the power to just stay on when you plug the battery in. Very dissappointed. Had to install a Mamba Monster 2200Kv setup in the vehicle which barely fits.
Here's the crappy power switch:
I am sending this to shawn and see what he says. If it is possible to splice the wires and they will still warranty the ESC, I am willing to give it a try. as it sits now though, I am going with this or I won't be able to run:
I liked how the speed passion setup went in the vehicle, but I am very dissapointed on how the switch just came apart. I got contacted by Shawn about the switch, and he is going to send me out a new switch and I can splice the power wires together to get my by. Just need to confirm which are the power wires to be sure.
As for the 2200Kv, I fit about a 15T pinion, don't think I can go smaller unless I grind on the motor case some.
The 2200Kv has A LOT of torque. Need to play with the settings a bit for this.
jhautz
jhautz's Avatar
06.09.2009, 09:03 PM
So what is the front and rear diff ratio on this buggy? A friend of mine has one on the way and we are trying to figure out what motor to get for racing on 5s. I'm thinking 1400kv Tekin. Not sure if you could gear it down far enough on the 1700 and 5s.
Can anyone tell me the f/r ring and pinion sizes. Thanks.
to make it...
or break it...
Silent...But Deadly
gixxer
gixxer's Avatar
06.09.2009, 10:29 PM
I believe its 11/43. I have the 1400kv in mine, but I run it on 6s geared 17/40. Its more then I need for the track and ended up with the punch at 3-4 on the tekin esc.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
Marvin
THE Paranoid Android
Marvin's Avatar
06.10.2009, 05:14 AM
It's 3.909090909 (or 11/43 as gixxer says).
By the way, I've just sold my Hyper 9E. Not because I don't like it, but more because I just don't keep cars for that long. I did like the handling, though durability appeared to be an issue with it. Also, I kind of like home-grown conversions more, you can put your own personality into it. So now I'm building a D8!
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
FG101C
06.10.2009, 11:35 AM
Well if any parts need to be boiled, boil those D8 parts, especially the front spindles and carriers.
saucisse
saucisse's Avatar
06.10.2009, 01:16 PM
I know someone did ask about it in this thread and I was also looking for it so here it is:
Hyper9e manual in pdf file
http://ofna.com/pdf/14351-HYPER-9e.pdf
____________________________________________
I don't suffer from insanity, I enjoy every minute of it !!
Gary NJ
06.10.2009, 04:44 PM
The HB plastic is very durable, no boiling needed.
FG101C
06.10.2009, 08:49 PM
I'm just giving Marvin a heads up. I had a D8 and broke two spindles and two carriers on easy landings. Friend of mine broke one also.
gixxer
gixxer's Avatar
06.10.2009, 11:39 PM
still very happy with mine. only complaint I have is the front arms and ofna is suppose to have a new version coming out.
Marvin
Marvin's Avatar
06.12.2009, 04:00 AM
I'm not complaining about the car, or parts. It's just, I change cars very often, as I like experimenting with something new. The 9E just didn't quite suit my purpose. I can get at most 12 minutes on the track with the batteries I use. I'm looking for 20 minutes, so I have to change packs. No-one does packs large enough - capacity wise - but small enough to fit in the box nicely. I would need ~6600mAh at 18.5 V to acheive this. No-one in England imports such a battery.
My new set-up is two 18.5V 3300mAh packs in parallel, one each side of the centre driveshaft. This works better, as it doesn't off balance the chassis so much.
I know I could have got a 6S pack that would work, but, like many others, I don't want to run my MMM on 6S for reliability reasons.
Cain
06.15.2009, 12:51 PM
I haven't had much to report here. I am waiting on getting my part back from ofna so I don't have a stripped screw sitting there. hope to see something end of this week, maybe beginning of next depending on when they get to it.
Then after that, may finally get to give the Silver Arrow ESC a try when I get it back with the switch replaced. I am very curious to see how much smoother sensored operation will be compared to my experiences with the MMM and Neu 1512 2.5D/F setup.
stone5334
06.17.2009, 10:04 PM
Cleaning this buggy after its first race was brutal. Not having stone guards with the giant body that doesnt fit the car = a mess! My first mod was to fit a guard on the right side. The right takes all the damage <Servo, ESC, transmitter box, and motor> The left side doesnt have anything to get destroyed, the battery box takes the beating. FYI the body is a JC High flow for a RC8 trims out fine.
Name:	Stone guard 1.JPG
ID:	7279   Click image for larger version
Name:	Stone guard 2.JPG
ID:	7280   Click image for larger version
Name:	Stone guard 3.JPG
Name:	Stone guard 4.JPG
Cain
06.25.2009, 04:33 PM
any more news guys?
gixxer
gixxer's Avatar
06.25.2009, 09:47 PM
nope, still really like mine but have to send my tekin in for service so 8th scale is out for a week or two.
