New Mamba software (beta) posted today
Pdelcast
Pdelcast's Avatar
New Mamba software (beta) posted today - 07.19.2010, 06:19 PM
Added some new features, including true torque control (should be very interesting to see the applications for this!)
Patrick del Castillo
President, Principle Engineer
SunnyHouTX
SunnyHouTX's Avatar
07.19.2010, 06:21 PM
Getting it now. I can't wait to try this out at the drag strip. Thanks PDC!!
One question Patrick - can we hold full throttle on a 7700Kv or 9000Kv motor on 3S lipo for 3 seconds? That's what we use on our set-ups but I'm a little concerned about grenading a motor doing this. What do you say? Also, how is this new torque setting different to punch control? And can it be used on sensorless motors? Thanks.
Edit: Or do you recommending on running 2S for the motor test and then go to 3S later? Will that be as effective as running the raceday voltage for the test?
brushlessboy16
brushlessboy16's Avatar
07.19.2010, 06:42 PM
Installing now :)
scarletboa
scarletboa's Avatar
07.19.2010, 07:14 PM
I've been waiting for this for too long.
Finally!
I will install this new update right away.
07.19.2010, 07:17 PM
Explaineth please?
bryan
bryan's Avatar
07.19.2010, 07:26 PM
Explaineth please?
NEW---BETA ---SOFTWARE---
marzac2
marzac2's Avatar
07.19.2010, 07:56 PM
I think he means explain the new features.
Losi 8 Buggy + Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM, MGM, Xcelorin ESC's
Tekno Neu "square can" brushless motors
Polyquest - Neu - Flight Power LiPo's
Semi Pro
Semi Pro's Avatar
07.19.2010, 10:16 PM
your my hero, thats going to be nice in my touring car, my diffs will be thanking you too
FG101C
07.19.2010, 11:37 PM
Ok, updated the firmware on both my MMM and MMP. I see a problem. If I barely give throttle the car creeps forward, then jerks forward to almost full speed for a second them calms back down, if I hold the throttle just barely it continues to do this lurching forward then slow then lurching again.
This is in two cars two separate esc's, MMM and MMP. Going back to previous firmware.
Pdelcast
Pdelcast's Avatar
07.20.2010, 10:36 AM
Try this--
Turn off punch control. Set torque control to "7".
Try driving and see what it's like. If you get lots of wheel spin, try setting torque control to half the value (3.5)
Remember, higher values means MORE torque is allowed. Lower values means less torque allowed.
Torque control is designed differently than punch control. It doesn't ever limit the throttle change, but limits the amount of torque that the motor is allowed to make.
Play with it a bit. We are still refining the software. :)
Pdelcast
Pdelcast's Avatar
07.20.2010, 10:38 AM
LOL @ Thomas....
We always do that.
bdebde
That's All Folks!
bdebde's Avatar
07.19.2010, 11:42 PM
Did you reset full throttle, brake, neutral?
FG101C
07.20.2010, 12:02 AM
Recalibrate? Yes, I recalibrate after every time the esc is plugged into Castle Link.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
07.20.2010, 01:26 AM
This "torque control" could be great. I'm seeing it as an aid for throttle control in the infield without compromising (possibly even increasing) speed in the straight.
Could this be a step toward traction control? Is there a way for the esc to detect rapid changes in motor rpm so it adjust the motor torque accordingly? Then ABS breaks next! :)
Area 52 Ranch Raceway
T.R.C.R.
whitrzac
Can't catch this...
whitrzac's Avatar
07.20.2010, 05:29 PM
ABS already have it, as for TC control, they had it on a few reaaaaaaly old brushed esc's and it worked sooo well that ROAR banned it...
