12.29.2007, 02:27 PM
But much cheaper. Im liking those- about £25 for a motor more than twice as powerful as a hvmaxx... What are your thoughts/experience of them- I think the 2000kv item looks right for my needs, maybe on 14 cells? I will haveto get some 5mm bore pinions, and have a poke with the gearing calculator...
EDIT: I wouldnt be against trying some normal or other hybrid outrunners either, I just dont have that much experience with calcualting which ones have enough torque for my application. Since Im using the old gmaxx style motor mount, motor diameter is not a limiting factor- I can always fab up a new motor mount part if it is larger than 25mm spacing for the mounting screws. Only thing to bear in mind is that I have 6 sets 7 cell packs, so the kv/voltage range of the motor & esc could be a potential issue sometimes.
lutach
lutach's Avatar
12.29.2007, 03:41 PM
I ran an Align 600L with 36 volts, which is way more then they were supposed to ever see. I like that fact that they have a lot of torque and you can use that in your favor. When I get my chassis design fully finished, I'll get a motor simular in design, but made to work with 36 volts and they are bigger then the Align 600.
mustbnitro
12.29.2007, 08:53 PM
WOW, I am impressed with the knowledge on this site. I am a hardcore newb with BL, but have ben in the hobby for years yet in has been a decade since I have had an electric (no such thing as BL back then). I am buying a Mamba Max and doing the stage one mod myself. I am an engineer and cannot leave anything alone, I was planning on adding better caps, but it is great with the step by step information on here on help you with disassemby and reassembly. This is great to see people not going out and trying to fix it with more money, but with knowledge and research.
kingiggy262
BL-Revo
01.30.2008, 07:19 PM
Just ordered a Mamba Max now i'm going to do the stage 1 mod! I ordered everything except for the Zener TVS diode because I couldn't find any singles and didn't want to pay $6 + shipping at Digikey for 10 when I only need 1.
So does anyone have any extra Zener TVS diodes that they would be willing to sell to me? Is there somewhere else that I could get one for a reasonable price?
These are surface mount 1500W and 27V. Link to Digikey: http://www.digikey.com/scripts/DkSea...C27AT3GOSCT-ND
Thanks!
cadima
04.16.2008, 06:57 PM
What is the point of these Zener diodes? What is there function, and exactly how do you solder these things to the board? Thx!
04.16.2008, 07:01 PM
I believe they are refered to as 'voltage clamps', and the purpose is to absorb transient voltage spikes that might harm the cap or batteries... something like that I think i read a while back...
They are surface mounted normally, so good soldering skills and a good iron are required.
DrKnow65
DrKnow65's Avatar
04.16.2008, 07:24 PM
I believe suicideniel is correct about the "clamp" function. I just soldered mine to the back side of the power board where the battery leads poke out.
GriffinRU
04.18.2008, 01:53 PM
04.16.2008 07:24 PM
DrKnow65
04.16.2008 07:01 PM
- Just to add for the comments above
Zeners/Transorbs voltage was selected to protect FET's from voltage spikes, running at 4-5S close to FET's rated voltage and for caps. With temp going up caps rated voltage goes down as well over the time, so to keep them happy I installed zener.
And as bonus reverse polarity protection for FET's, not for wires and bad soldering :)
DO NOT CHECK it!
cadima
04.18.2008, 07:27 PM
Are these diodes polarized? I have some and there's no indicators on them to suggest there's a positive and negative side. Thanks!
DrKnow65
DrKnow65's Avatar
04.18.2008, 07:28 PM
Yes they are, I'll have to remember which way to put it on but thewre is a little C shaped notch in one side of the top of the diode...
DrKnow65
DrKnow65's Avatar
04.18.2008, 07:32 PM
Notch goes to the positive side.
cadima
04.18.2008, 07:39 PM
cool, thx
GriffinRU
04.18.2008, 08:07 PM
rchippie
rchippie's Avatar
04.18.2008, 08:30 PM
ARTUR do you have any plans on putting 2 Monter mamba's to make a super controller .
REAL MEN RUN BRUSHLESS
cadima
04.18.2008, 09:09 PM
Does having the booster cap on those long leads decrease the effectiveness? Or is it ok so long as the wire guage is low enough to keep inductance down (something like that)?
