Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unsullied_Spy
Unsullied_Spy's Avatar
07.16.2009, 12:53 AM
Another vote for the plug-in. I chose to get the plug-in over the battery one because it is always working when you need it, no batteries to worry about. I don't know for sure, but it seems to me that you'd get more torque out of a plug-in model as well. Mine's a 300 series and very gutless but there's no voltage drop when plugged into house current.
George16
Supermaxx
George16's Avatar
07.16.2009, 01:06 AM
Yes, you do get more torque with a plug-in. I have an inverter in my 1:1 car so no problems taking the Dremel with me anywhere.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
07.16.2009, 01:17 AM
I love my plug-in Dremel...I also have a cordless version, but I never use it.
-Chad
PM ME IF YOU HAVE THE BELOW:
07.16.2009, 11:42 AM
Another +1 for plug-in dremels. If you want portable, then get the flex-shaft adaptor, you can move around alot more with it that way. Having a battery operated one isnt worth squat diddly if it only lasts a few minutes and hasnt got much power, and who takes a dremel with them when they go bashing/racing anyway? Not many people I imagine...
Kcaz25
Kcaz25's Avatar
07.16.2009, 12:22 PM
HERE is the dremel I'm talking about. But they make it sound so awesome!
HERE is the piece of junk I have now.
But maybe you guys are right about the plugin
07.16.2009, 02:13 PM
Yes, I have used the li-ion. It is so weak I can put my finger on the edge of the cutting wheel and stop the dremel at full speed without getting cut...
Kcaz25
Kcaz25's Avatar
07.16.2009, 02:33 PM
Yeah man sounds like good advice and all but I've cut myself on accident a few time with mine. And its 7.2v 20,000rpms. Maybe you left out some detail like it wasn't on or something...
07.16.2009, 02:53 PM
It was on.... I think my charger may have been bad possibly, there's no way dremel would market a product that you can stop with your finger.
florianz
07.16.2009, 02:49 PM
what about making it a "project x"-Dremel by adding some more volts?
I did that with my old cordless screwdriver... with my girls's cordless vacuum cleaner (adding more and better nimh's) and with my acoms hayabusa by replacing batts with a crappy 3s-lipo (-->see project x).
more volts - more fun
flo
Chadworkz
Chadworkz's Avatar
07.16.2009, 02:57 PM
I like the digital Dremel...not the RPM read-out, but the digital sensor that gives it the ability to maintain the set RPM under load, but I wish it didn't have the weird turn-down grip on the end. If the 400 series was digital, it would be perfect!
-Chad
Kcaz25
Kcaz25's Avatar
Thumbs up 07.16.2009, 03:14 PM
flo
Not a bad idea! I've actually thought about that some... I would worry about bearings and the motor over heating.
Definently a bad charger. That is a shame. Plug that battery into your hobby charger with aligator clips and "let her rip".
Still that is a bad sign that you got a bad charger.
Yeah! When my uncle comes from georgia for the holidays and vacations he always brings his digital dremel! I really like how you can add 1000rpms with a button. Up to like 40000rpm. I may get this one.
Guys I fixed the tranny! All it took was cutting down the raised place on the 2nd speed input gear! No robots required! Sorry Chad I knew what you meant.
07.16.2009, 03:37 PM
I ended up trading the dremel for something, and I'm not sure what became of it after.
Chadworkz
Chadworkz's Avatar
07.16.2009, 04:23 PM
Good deal, man...glad you got everything working smoothly. Can you take pics of what you did? I will be needing to do this very soon, so I would like to see exactly where/what I need to do...thanks in advance!
-Chad
Kcaz25
Kcaz25's Avatar
07.20.2009, 11:07 PM
Okay so check it: After further investigation I found it was still far too binding.
Can you see right where the camera is focusing? At the end of the idler gear shaft carrier their is a ring that sticks out to catch the inner part of the ilder gear bearing, yeah well that must be cut down some... just go by feel I suppose but the amount I grinded down here was perfect.
Here is the part I mentioned earlier. You see the left side of the gear? The side facing the threads? It is a raised section that is made to ride the bearing rings just like mentioned just above. It must be ground down. Don't go by the amount I ground because I cut too much off giving a little play back and forth. Just go by feel.
Thats it! Smooth as butter. Still this tranny has soo many problems. Like the screw holes are all way to shallow. Its really a shame. Its like they never actually installed this thing.
I hope this helps!
-Zack
mkrusedc
NeuMaxx
mkrusedc's Avatar
07.16.2009, 08:46 PM
Zack,
Glad things worked out.
