Rivermaxx
02.17.2010, 10:40 PM
I personally want my mount lower and way forward on that chassis.Might have to do a little trimming on the rear plate and make a center skid but its doable.
George16
Supermaxx
George16's Avatar
02.17.2010, 11:23 PM
I received mine yesterday and will be mocking it to my gmaxx chassis and try to make a skid. If I'm not satisfied with it, I'll buy a new skid from Mike.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
02.17.2010, 11:41 PM
I can make custom length aluminum drive shafts - will have to get a system in place here for efficiency, though.
We need it.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
We need it. - 02.18.2010, 01:20 AM
With RCalloys gone we could really use the help Mike. Granted the need for custom drive shafts is not one of those gold rush factors in R/C, but with the type of builds that allot of us do with these vehicles we would be lost without a solid supplier of good quality shafts to depend on. Plus most of what any of us can find in stock or aftermarket replacements is hardly durable. Having a solid set of driveshafts can elliminate the worries of having a weak spot in our drivetrain that can result in set after set of replacement shafts. Thanks for the offer to fill the gap MM.
SUPERMAXX YOUR LIFE.
Rivermaxx
02.18.2010, 09:17 AM
Will aluminum be strong enough? I wonder if 7075 would work best because its harder stronger material.
I was thinking about making another Gmaxx chassis plate much like the one I made before without the tranny cutout so I can have a spot to mount the CD mount without the need for custom made shafts. I'll make a cardboard cutout once I get home from work(it's 1:00 in the afternoon here in Japan) and post some pics about this idea of mine. The aluminum plate will be 3mm thick (aircraft grade 6061T6 aluminum) and I think it will be robust enough to hold the cd in place.
I am thinking the same thing but with 3mm carbon fiber plate.
feistyacorn
feistyacorn's Avatar
02.18.2010, 11:15 AM
That would be awesome Mike! I think that I found a way to mount the CD using the stock bottom plate. It only requires a little chainsaw action on the servo plate. Should be all good once I get the Slipperential and driveshafts.
bl THUNDER....thanks for the parts Mike!!
plettenbergs
plettenbergs's Avatar
bl THUNDER....thanks for the parts Mike!! - 02.18.2010, 12:41 PM
ONLY TOOK 5 MINUTES TO INSTALL!!!
plettenbergs
02.18.2010, 12:45 PM
forgot this picture!
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
sexy! loving that setup man... nice and shiny... when do we get to see it in action?
02.18.2010, 12:49 PM
So, umm.... plettenbergs.... Maxxler chassis?
plettenbergs
02.18.2010, 12:51 PM
i have ordered a Fioroni center diff spur gear....it does not have right gear on it now...i will run 5s2p Zippies!!
anyone know if Kyosho gear fits on Fioroni diff?
George16
Supermaxx
George16's Avatar
02.17.2010, 11:55 PM
Revo with OS .18TZ
George16
Supermaxx
George16's Avatar
02.18.2010, 09:20 AM
Beau, I just did the mockup and in order to mount the CD into the gmaxx skid/chassis itself, I need the cd mount to have an additional 14mm in height. I'm still going to make my chassis plate but with another skidplate to mount the cd in place.
It will be heavier but it's okay since the powerplant can take care of it anyway. I want it to be a little bit heavier so I can do higher speeds.
Revo with OS .18TZ
Finnster
KillaHurtz
Finnster's Avatar
02.18.2010, 12:38 PM
FWIW, Cen makes sliders for the giant GST that have steel ball joint ends which fit 8mm pinions.
These may be a flexible solution until the custom dogbone issue gets resolved.
nitrostarter
nitrostarter's Avatar
02.18.2010, 02:30 PM
Sold out... Any more coming Mike?
N. Rustler conversion
