hyperasus
hyperasus's Avatar
10.21.2007, 04:24 PM
I could care less about the centrally mounted motor. And the problem with the stock Emaxx tranny is that it doesn't have a real slipper. As far as I am concerned if it doesn't have a Revo type slipper then its useless. In other words, stock Emaxx tranny = useless worthless piece of crap.
sikeston34m
sikeston34m's Avatar
Smile 10.21.2007, 04:33 PM
The upgraded "original" E maxx tranny has disappointing limitations.
I run an upgraded input shaft, and RCM steel idlers. The next weakest points are the plastic output gears and the drive dog.
On different occasions, I've stripped each of the lower output gears. I've broken the teeth off the drive dog that engage with the output gears. I've also stripped out the hole in the drive dog where it rides on the output shaft.
The plastic gear teeth are weak. It's not that hard to shear them off.
I don't think the plastic can take the heat from being spun so fast. The material gets soft when you push it the hardest.
I even tried talking to a machine shop about getting steel ones made. The originals are metric, hard to identify and hard to acquire gear stock for. So I ran into a dead end on that venture.
I'm VERY excited about a transmission that is 2 1/2 times stronger than stock. The stock one isn't bad, but it comes apart when you exceed 50 - 55mph or so.
I'm DEFINATELY looking forward to putting this new transmission to the test.
10.21.2007, 04:45 PM
It's too bad that the tranny couldn't be sealed so that you can run some thin fluid in there to help with the heat.
What about venting the tranny case? Cut some holes and then glue in some metal screen (like in a screen door) to keep debris out, but get some airflow? Either that, or simply run a center diff instead of a tranny...
sikeston34m
Smile 10.21.2007, 04:52 PM
I've had some pretty good luck in sealing the tranny. That's another mod I always do.
I use silicone on the mating surfaces during assembly, then use rubber sealed bearings on the output shafts.
I haven't experimented with different vicosities on the lube, but I use Lucas oil stabilizer. I think maybe it's a little thick, but seems to work good for gear oil.
I don't think I want to vent. Dust and abrasive material is the enemy of gears and bearings.
Before the new E Maxx info was released, I was pondering a FLM case to dissapate heat and all steel gears. I think I'll just start with the new E maxx instead.
JThiessen
JThiessen's Avatar
10.21.2007, 05:00 PM
Originally Posted by hyperasus View Post
OK then gorilla needs to get on this right away before I have to throw my G3R's n the closet and buy a couple of these new E-Maxx's. Really need a tranny worth wizzing on for both of my G3R's.
Shouldnt be too tough to figure out how to get one in there. Look at all the much more complicated things that have been figured out on here.
10.21.2007, 05:03 PM
Fair enough. I assume that the new Revo-type slipper can actually take Revo spurs though - MOD1 pitch- , judging by the design of the slipper pads & the screws etc.
Getter Robo
RC Monster Fiberglass
Getter Robo's Avatar
10.21.2007, 05:22 PM
I've been using these Ebay gears in my E-LST since the Tranny was in an E-Maxx without any big signs of wear. Unfortunately, that ebay guy never wanted to tell where he got them or which machining company he asked to make them.
But maybe I shouldn't advertise them so much since I've never went over 50mph (40 at most)
Tesla 4 president!
sikeston34m
10.21.2007, 05:34 PM
Are those the ones that are advertised as Titanium?
I've asked a few questions of the guy selling them with no response. That tends to steer me away if they won't communicate. IF it's the same guy.
10.21.2007, 07:31 PM
I can understand that, but people use exposed center diffs all the time with rare issues. As long as the bottom is vented to let any small debris fall out, I don't see where it would be a problem.
coolhandcountry
coolhandcountry's Avatar
10.21.2007, 08:01 PM
It looks as if the trans may have same mounting style as a revo trans.
Peace!
Country
Help support the
Rc-Monster
Buy here
squeeforever
squeeforever's Avatar
10.21.2007, 09:16 PM
Why not look into the gears from 4wdrc.com?
10.22.2007, 10:30 AM
These ones
Says they are 6061, but little else really. Still, anythings better than brittle plastic, probably.
sikeston34m
Smile 10.23.2007, 12:40 AM
I just noticed Tower has redone their list price. $369.99
http://www3.towerhobbies.com/cgi-bin...=LXTJR4**&P=SM
gixxer
gixxer's Avatar
10.23.2007, 01:11 AM
thats a lot more realistic then the $528.99 they had listed.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
Finnster
KillaHurtz
Finnster's Avatar
10.23.2007, 10:31 AM
In regards to the new diffs, what effect do you think that new center piece will have. Its looks like some sort of brace, but I'm wondering what it will do to the diff tuning. Ie is there any possibility that it will allow lighter diff fluid to be used to acheive the same amt of slip?
Big hope as the Revo center diff uses the same diff cup. Anything to add some tunability to that diff (when 500K even gets thin... )
